HI thanks for your reply,
Yes the problem was in the lower operators panel, i air cleaned the board and re-adjusted a twisted ribbon connector.
all is fine ,
thanks ,
all is fine ,
thanks ,
hello, Mr Sauamikat'
you have helped me in the past with your knowledge.
i have a problem with a Traub TNS 30/42.
the machine will power up ok , no alarms .
when the drives and hydraulic button is pressed the drives are switched on but they are working for only ten seconds and then switching off. this is repeated every time i press the drives on.
there are no NC alarms just A016 when the drives go off, but the alarm is cleared by switching drives off button.
the main drive unit in the machine cabinet is showing a LED indicator status : error on power side or UE OFF at RF ON , the main drive is a AMK arnorld Muller D-7312,
can anyone advise with this problem please.
kind regards
Mr Des Williams
Hello everyone,
we just buy a TNL12/7 1999 TX8I and allredy have some problem. After we start the machine we recive an error code Z071/1 on all axes.Can sombody help us with an advice or a setup manual(parameter list and configuration)?
best regards
HELLO Die Traub-Experten
I have Traub TNS 60 I need to input the parameters kindly publish the method for manually inputing the parameters.
Saja
good afternoon
could you help me, I try to communicate with the mc161 card in a TRAUB TNM42 control system TX8F, I need to reset parameters, I have 4 computers without data and 2 with all the information, could you please help me
Hello,
We are running a TNX65/42 and have lost our MSP orientation. How can we reset it to the desired zero.
I have not been able to find a screen that gives it or shows actual C axis position.
Hello,
On our traub tnc65 machine, the spindle and counter spindle are not concentric, how can it be set?
I do not have the documentation for the machine
