585,705 active members*
4,511 visitors online*
    Oct 2010
    CNC Software Contol Programs
    Hi
    Im looking for a commercially available software solution for the control of our CNC programs.
    We are manufacturing components for medical devices therefore need to have ideally:drowning::drowning::drowning: the following level of control
    • Change Control System
    • Revision level
    • Approval system
    • Software security ie
    • Password Restricted Access at defined levels of authority and permissions
    • Traceability
    • Change Control
    • Electronic Signatures
    • i.e Part 11 complience or close to
    It would be much appreciated if someone can point me in the right direction
    Many Thanks
    M
    Dec 2005
    594
    What OS are you planning on running your CVS software on? ClearCase is one of the bigger vendors, and AFAIK, runs on both Windows and *nix systems. Got no idea what Part 11 compliance is, so you may have to check with the vendor on that.
    Mark
    Oct 2004
    147
    I work for a machine tool and automation company. We have developed a flexible framework that can use virtually any hardware(or combination thereof).
    Currently Galil,RSI(Mei) and MicroKinetics are implemented.
    The interfaces can be custom configured, motion profiles and process sequences can be customized on the fly.
    I am considering making this project available as open source, still debating interest level.
  1. Software to backup and interchange programs between different controls.
    By steelhead9 in forum DNC Problems and Solutions
    Last Post: 03-04-2009, 02:02 PM
  2. What software do you use to manage CNC Programs
    By bfoster59 in forum DNC Problems and Solutions
    Last Post: 01-24-2009, 05:12 PM
  3. Machining a contol panel.
    By macona in forum MetalWork Discussion
    Last Post: 10-29-2006, 09:14 AM
  4. PDA software to transfer programs?
    By WOLOG in forum DNC Problems and Solutions
    Last Post: 05-04-2006, 02:12 PM
