585,763 active members*
4,374 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How to profile a pocket with an end mill?
Results 1 to 13 of 13
    Oct 2010
    Hi, I am a student. I got this assignment in which i had to make a .25 deep pocket in a part and to profile the edges with an end mill. But i missed the class in which the teacher explained how to do it. I somehow managed to do the pocket but have no idea how to profile the edges with an end mill. When i try to do it it simply cuts through all the edges of the pocket. Does this have something to do with the chaining or is it something else. Please help me as I have to submit this tonight and only have 6 hours left. Thanks
    May 2007
    312
    what toolpath are you using and can you post a screen shot or the file?
    Oct 2010
    Here's the file BIKRAMJEET_GILL2 (1).MCX
    I have to profile the edges of the pocket using a slot drill and the toolpath is contour.
    May 2007
    312
    save it in X3 or older, I am getting a corrupt error so I am assuming you are X4 or newer.
    Oct 2010
    I am at home and i don't have mastercam here. I only have the file. Can u please figure it out with this much information cuz I am failing the course and this is the only thing that can help me pass. Thanks a lot again.
    Apr 2008
    49
    I did saved it as older version of Mastercam
    BIKRAMJEET_GILL2 .MCX
    Not sure what you're trying to do, are you just trying to run A finish pass? What do you mean cutting through all edges of pocket? Pocket has .063 rad on all corners but you left .200 stock on the walls.
    Oct 2010
    I am trying to profile the parts where the round corners meet the rectangle with a slot drill using a contour toolpath. Thanks for uploading the x3 version.
    Apr 2008
    49
    jamie1 I'm working on it, having a little problem with control definition but will try to get by.
    Apr 2008
    49
    Here is the file, hope it is how you wanted it.
    BIKRAMJEET_GILL2 -2.MCX
    I moved in your rough pocket to leave only .062 so the 1/8 end mill can finish in one pass
    I also changed your rough tool path from conventional to climb.
    Jun 2010
    60
    -Hijack on-
    What's your reason for missing the class?
    Your choice to answer truthfully, or even at all!
    -Hijack off-
    Oct 2010
    I woke up too late lol
    Jul 2009
    86
    Quote Originally Posted by jamie1 View Post
    Hello, I had some extra time and had a look at your part.
    I edited some of the tool-paths and added the finishing contour you were looking for on the pocket walls.
    You should also note that you had a duplicate arc in the bottom left hand corner of your pocket that was causing some chaining issues.
    The "delete duplicates" function is very useful when you're just learning to create geometry in MCX .
    I can e-mail you a copy of the updated file if you post or PM me your e-mail, as I cannot attach .MCX files here.
    Apr 2003
    3578
    Jamie1 What school here in Cali if I may ask?
    Cadcam
  1. HAAS mill - G150 pocket cutting cycle
    By colton_m in forum G-Code Programing
    Last Post: 03-10-2010, 01:58 AM
  2. Pocket help
    By fourwheeler in forum BobCad-Cam
    Last Post: 11-24-2009, 01:53 AM
  3. Pocket mill leaves islands V21
    By SteveS in forum BobCad-Cam
    Last Post: 08-02-2009, 04:30 AM
  4. TNC145 programming: pocket mill canned cycle
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 01-16-2008, 06:17 PM
  5. changing mill pocket toolpath to lathe-v9
    By scolee in forum Mastercam
    Last Post: 03-25-2007, 03:39 PM
