585,763 active members*
3,974 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Can you use tool comp for X-Z moves instead of XY
Results 1 to 9 of 9
    May 2005
    12
    I need to mill out a rounded bottom cavity but I need to tool comp for my 1/2 inch ball endmill. Before you ask, No I can not get the CAM software to do the comp. So can I get the Haas to do tool comp if I select the x-z plane then just do a G41 or G42? Does this even work?
    Jan 2009
    34
    I may be wrong but i think if you try using g41 or g42 in any other plane than g17 you will get an alarm. The alarm will probably say something like cutter comp illegal in x-z plane
    Apr 2005
    713
    It's right in the manual.
    If cutter radius compensation is selected (G41 or G42), you may only use the XY plane (G17) for circular motion.
    Apr 2006
    235
    Can you use the G43 Tool lenght comp to compensate for the z axis and then the G41 for the X?
    Jan 2009
    34
    No as i said last night if you comand a G41 or G42 in any other mode than G17. You will get an alarm.
    2932
    Quote Originally Posted by Matt@RFR View Post
    Here's the section from the manual Matt was referring to.
    Attached Thumbnails Attached Thumbnails Haas G18 G19 not allowed with CRC.jpg
    Apr 2006
    235
    I mean, if he is cutting a rounded bottom cavity using XZ moves, can't he just G43 tool comp/tool length offset to adjust for the depth? If he is using XY moves with stepped Z, he also use G43 to adjust for depth and G41 to adjust for the XY dimension of the cavity, right?
    Does using XZ moves for round cavities give a better finish?
    Oct 2010
    Try G141 I believe that this is 3D cutter comp.
    Jan 2009
    24
    Smile Cutter Comp in XZ
    Depending on your control, you will have to give it a command to change to an XZ plane, G17 is the XY plane for a Fanuc Style Control, If I remember right, I'm old. the G18 or G19 command will change the cutter plane to an
    XZ plane which will allow you to use your current cutter comp number and the same offset table for cutter dia. But remember that you will have to imput the G17 command in the next line to bring you back to normal XY programming.
  1. Rapid tool moves when not cutting?
    By Fleck in forum G-Code Programing
    Last Post: 04-22-2009, 07:26 AM
  2. tool comp
    By blighty in forum Mach Mill
    Last Post: 01-07-2009, 03:14 PM
  3. Tool comp questioin
    By JV58 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-23-2008, 01:08 PM
  4. Fanuc 11m Tool Comp
    By Jfrahm in forum Fanuc
    Last Post: 07-29-2007, 11:01 PM
  5. Cycle Time for Rapid Moves and Tool Changes V9.1.1012 Turn
    By jmullett in forum Dolphin CAD/CAM
    Last Post: 02-07-2007, 11:32 AM
