585,715 active members*
3,927 visitors online*
Thread: OKUMA LU300
Results 1 to 15 of 15
    Jun 2009
    108
    Unhappy OKUMA LU300
    Hello, I have an alarm 1185-20 ALARM A MCS VELOCITY DEVIATION OVER SPDL-1 80010006 in a machine LU300 with control OSP, I'd reduce cutting velocity several times, but the alarm appears again, the manual says that change the motor or the drive, but I would like to know if I can get more options, somebody knows how?:nono:
    Jan 2008
    575
    Antonio, did you try gearing the spindle down? M43-41? Just to see if you get the same Alarm?
    Are both turrets cutting at the same time?
    Robert
    The beaten path, is exclusively for beaten men.
    Jun 2009
    108
    Let me try, not, just one turret....
    Apr 2009
    1262
    Has this machine been connected a while and this is a new problem or is this a new install?
    The reason I ask is sometimes I have seen this alarm if the voltage is too low or the cables are too small running to the machine.
    Start with the simple things first. Also are you just taking too heavy of a cut? Let us now conditions where this occurs.
    Best regards,
    Mar 2009
    1982
    and check the spindle tooth wheel, which is sensed by magnetic encoder. Perhaps it is dirty.
    Jun 2009
    108
    Exclamation Done
    We find the magnetic encoder dirty, we cleaned it and the tooth wheel, the machine works it two cycles, then appears the alrm 1159-20 ALARM-A MCS POWER UNIT OVER LOAD SPDL-1 6520652.
    do you think that we must change the encoder?
    Feb 2008
    52
    Try removing the pulse encoder and cleaning the face. The brass part of the encoder will sometimes build up a coating and make the signal distorted. When replacing the encoder make sure to set the gap .003 to .005 thou., you can set with feeler gages.
    { make sure not to damage the brass reader head during removal or reinstall }
    any mechanical or electrical device that transmits or modifies energy to perform or assist in the performance of human tasks
    Jun 2009
    108
    Question Difference
    Thanks! Do you know what it's the difference between encoders:
    E3051-396-015-1 (original)
    and
    E3051-396-012-4 ?
    Because I get the second one....
    Feb 2008
    52
    Truth be known OKUMA is famous for changing part #'s from your original parts book. Probably an engineering change or a newer model.
    Jun 2009
    108
    Unhappy Thanks
    I've changed the encoder by the original, but the problem appears again, I'm trying to get a drive MIV...
    Oct 2010
    25
    Antonio which the Okuma control OSP U100L/E100/P100 or 200 please check the gear runout this must be between 0.010 or 0.020mm also you has to adjust the distance from the magnetic encoder and the gear, the distance from this has to be no more than 0.006but you need to take care because the runout on the gear can be more than that and can damage the magnetic encoder please help me with the control type in order to get tha alarm meaning also you can check the resistance on the encoder
    Jun 2009
    108
    Question Doubt
    OSP-P200L, I've changed the drive, and the machine works OK, but I have the new encoder installed, I would like to use the old one, but , I'm afraid to damage the new drive, what do you advise?
    Jan 2008
    575
    If it's not broke, don't fix it. You were having trouble before :drowning: now it is running :banana: Leave it alone. Keep the old encoder in a safe place, when/if the problem returns you know where to start.
    Oct 2010
    25
    i am agree live it on a safe place
    saludos
    May 2019
    6
    Quote Originally Posted by Antonio Arguijo View Post
    Hi, I will have to change magnetic encoder on my Okuma MX45VA could You tell me when You change the encoder did You do some adjustment in OSP Or did You adjust with osciloskop, Or just change Old with new mechanicly?
  1. Replies: 4
    Last Post: 10-02-2014, 04:58 AM
  2. maintenance manual lu300 or lt200
    By skidoo in forum Okuma
    Last Post: 04-06-2011, 03:19 PM
  3. Okuma Howa Vs Okuma
    By gcrudgington in forum Okuma
    Last Post: 07-01-2010, 03:11 PM
  4. Replies: 1
    Last Post: 08-28-2008, 02:09 PM
  5. Difference between a Okuma & Okuma Howa
    By 69owb in forum Okuma
    Last Post: 06-04-2008, 05:51 PM
