585,902 active members*
4,096 visitors online*
Results 1 to 1 of 1
    Jul 2007
    8
    possible build: slantbed lathe
    Hello all,
    Just wanted to introduce myself and the project i am about to undertake (or not).
    I have been reading this forum a lot, and also did quite some researching on the internet for several years, and I decided that it is time for me to start the build of a slantbed lathe.
    My goal is to build from scratch a cnc lathe / machine center.
    The pictures give a general idea, I made them in sketchup (the only program I can work with) they are not finished yet, but I will try to explain a bit further.
    So, where to start.. first thing I want to have 2 spindles opposite to each other, so that when parting the work piece I can grab it with the second spindle and do some final machining on the other side.
    The 2 spindles will be driven by one and the same DC servo motor (a baldor 180V DC 12 Amps/ 46,6 amps peak servo motor), I think that should give me enough power.
    Then I will have 2 beds on the Z axis, one with an 8 tool turret, and the second one with a 3rd spindle for milling, the spindle will be able to rotate by 45° plus and minus, and also move up and down for Y movement by about 100mm (4 inch). The 2 beds will be able to move independently from each other, but they will be on the same tracks. I will probably be using a Chinese high speed spindle for the milling part.
    I might be building is a chip conveyer, and a part extraction system
    Ideally I would have an ATC on the 3rd spindle, but that would be pushing it
    So far, although a massive amount of work, mechanically this will be doable, but software wise it will be a challenge. I have 8 axis, 1 axis/spindle, one spindle and several pneumatic cylinders to control.
    I have gathered some parts already over the past few months.
    This is what I already have and would like to use:
    - DC servo motor Baldor 180VDC 12 Amps/46,6 Amps peak (that is a massive 8388 Watts peak and 2160 Watts continuous power) I have 2 of these
    - 1000 line encoder with index, plan on using it on the spindle as the baldor motors came with a tacho
    - 5 stepper motors nema 23 (these are small ones, but I hope to be able to use them)
    - 6 gecko stepper drives G203V and one Chinese copy
    - I also have laying around 3 x G320 servo drives from gecko, don’t know if I will be using them
    - then I have a manual chuck 170 mm, and an automatic chuck also 170 mm, this one is intended for use with an hydraulic cylinder, but I hope this will also work with a pneumatic cylinder.
    - I also have all the pneumatics (controls and cylinders)
    - I have all the electronics (break out boards x 2 and a G100 from gecko that I can use as IO)
    I will take some pictures later this week form the parts that I have and post them here.
    What I still need:
    - a servo drive that can handle 180 VDC/40Amps
    - all the ball screws / nuts
    - all the linear bearings
    - all that involves the structure for the lathe
    - a cooling system
    - probably 2 steppers or servos
    - power supply(s)
    Any advice on this would be greatly appreciated, sources for the parts that I still need, and comments (usability) on the parts that I already have are also welcome.
    I have a standard lathe and mill at my disposal for making all the parts that I might need
    maybe I should mention that this is probably going to be a 2 year build or something, I can only work on it a couple of hours per week.
    Thank you for your time.
    English is not my native languish, I am sorry if there are things that aren’t clear
    Best regards,
    Bram
    Attached Thumbnails Attached Thumbnails slantbed lathe1.jpg   slantbed lathe2.jpg   slantbed lathe3.jpg   slantbed lathe4.jpg
  1. has anyone tried a slantbed lathe??
    By marx911 in forum Uncategorised MetalWorking Machines
    Last Post: 06-21-2012, 05:28 AM
  2. Yet another Aussie biuld log
    By mhasting2004 in forum CNC Wood Router Project Log
    Last Post: 06-02-2010, 10:44 AM
  3. Slantbed Taig CNC Lathe
    By sprinter in forum Taig Mills / Lathes
    Last Post: 02-22-2009, 05:12 AM
  4. First CNC biuld
    By ColdFire1990 in forum Open Source CNC Machine Designs
    Last Post: 11-11-2007, 04:07 PM
  5. new biuld 24 x 48
    By dertsap in forum CNC Wood Router Project Log
    Last Post: 06-06-2006, 04:57 AM
