585,973 active members*
4,081 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > syil xp5 trigger limit switch
    Nov 2009
    12
    hello
    I have a syil xp5 linear. I had to take the machine into parts because of clearane in the z-spindel and some other mecanical problems with the y-axis.
    I have now limit switch trigger during runnig a program in mach3 and need some idea how to trace the error. It is always in different nc-records. The machine and spinel stops. I supose it is some electrical problem. If somebody had some similar problem thanks for a reply.
    May 2005
    925
    it maybe a problem with the ground, check the back of the machine and veryfy the ground is OK. You can also try putting 500 as the debounce interval in the general settings it helps with noise.
    Good Luck!
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    Nov 2009
    12
    thank you peu
    where can i set the debounce interval. is this in mach3?
    May 2008
    667
    Goto Config - General Config - and look at upper right corner for debounce interval
    Jeff
  1. Limit switch replacement with proximity switch?
    By Normsthename in forum Bending, Forging, Extrusion...
    Last Post: 07-11-2009, 04:38 PM
  2. Limit swtich false trigger
    By HakBot in forum Benchtop Machines
    Last Post: 10-04-2008, 07:01 AM
  3. 4th axis trigger off coolent switch?
    By D.D.Machine in forum Uncategorised MetalWorking Machines
    Last Post: 10-10-2005, 09:04 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
