585,700 active members*
3,448 visitors online*
Results 1 to 15 of 15
    Oct 2010
    mori SL-15 canned cycle
    we have a mori Sl-15 w/Fanuc 10t control there is no option for G83
    is there any way to use G74 and have full retract out of the hole?
    or does anyone know what pram it is to turn on the option for G83
    Thanks Sam
    Jan 2008
    575
    It is an impossibility that the control won't support G83.
    What is happening when you try to use it? Alarm? Sitting? What function are you trying to use it for? C axis drill or lathe drill?
    The beaten path, is exclusively for beaten men.
    2932
    Quote Originally Posted by littlerob View Post
    Why is it an impossibility? G83 was an option, and Mori didn't include it with the machines.
    2932
    Quote Originally Posted by Prospot View Post
    Thanks Sam
    The only parameter I can find for G74 is 6217 (Return amount). Could you do it with a coolant feeding drill?
    Jan 2008
    575
    HUH? No peck drilling? Sorry I was wrong.
    Robert
    http://www.practicalmachinist.com/vb...cycles-152872/
    Nov 2007
    188
    Drill Cycle
    Here is a link to a custom macro drill cycle that could help you do the same thing.
    CUTTING TOOL ENGINEERING Plus | Pecking Order
    2932
    Quote Originally Posted by chucker View Post
    Most of those old Mori's didn't have the Custom Macro option turned on either.
    May 2007
    1003
    Quote Originally Posted by dcoupar View Post
    But the good thing about being "old" is that they can be turned on. Not that I am advocating it. Fanuc needs to make money too!
    Jul 2010
    369
    This is what I came up with for a full retract.
    Hope it helps you in some way.
    O00001 ( FANUC 10T)
    N01 G18 G20 G40 G80 G90 G98
    N02 G00 G28 U0. W0.
    (JOB 1 DRILLING CYCLE )
    N03 T0707
    N04 M01
    N05 G50 S400
    N06 G97 M04
    N07 G54 X0. Z.1 M08
    N08 G97 S400
    (DRILL FACE - G74)
    N09 G74 X0. Z-3. I0. K.2 F.01
    N10 G40
    N11 Z5.
    N13 T0700
    N16 M09
    N17 M05
    N18 G28 U0. W0.
    N19 M30
    May 2007
    1003
    Quote Originally Posted by Perfect Circle View Post
    O00001 ( FANUC 10T)
    N02 G00 G28 U0. W0.
    N03 T0707
    N04 M01
    N05 G50 S400
    N06 G97 M04
    N07 G54 X0. Z.1 M08
    N08 G97 S400
    (DRILL FACE - G74)
    N10 G40
    N11 Z5.
    N13 T0700
    N16 M09
    N17 M05
    N18 G28 U0. W0.
    N19 M30
    See post #4 by Mr. Coupar. G74 is not a full retract cycle unless you want to change parameter 6217 for every drill cycle.
    Jul 2010
    369
    Aye ...well I guess that param. is changed on my control, works for me Sorry.
    May 2007
    1003
    No need to apologize to me. If it works for you, then great. I'm not about to call you a liar. I don't know a tenth of what some of these guys know. What machine/control are you using? We have OT, 6T, 10T, 16TT, 18T & 21i-T controls on Hardinge, Mori, Daewoo, Takisawa, and Nakamura Tome lathes and it doesn't fully retract on any of them. How far does the tool clear the part on retraction? Is it always the same distance in front of the face? As I understand it, I would have to change that parameter for every drill cycle that used a different drill depth because it is a fixed amount.
    I almost never use a G74 for anything other than a chip break cycle for face grooves. I use the deep drill cycle that comes in Hardinge lathes in all our Fanuc controlled lathes. Well...with a few personal modifications of my own.
    EDIT: I notice you use a single block call. I assume your machine is an older one. All ours but one use the 2-block call. It is an older Mori Seiki. On 16i-/18i-TA controls the retract parameter for the G74 cycle is 5139. This is why it is critical to know your machine well before attempting to change any parameters. You could wind up in deep doodoo otherwise.
    Aug 2007
    31
    canned cycles look at prm 9104 on a 10/11 that has g83
    Jul 2010
    369
    :cheers:Its on an MSC-516 control , Mori SL-75MC...its prob. a Mori Param.
    May 2008
    84
    [QUOTE=littlerob;841555]HUH? No peck drilling? Sorry I was wrong.
    Robert
    CNCzone.com-The Largest Machinist Community on the net! - Powered by vBulletin[/QUOTE
    This link won't work? Any ideas?
  1. Mori MV 35
    By SteveY in forum Mori Seiki Mills
    Last Post: 10-21-2010, 06:25 PM
  2. Mori NL
    By positiverake in forum Mori Seiki lathes
    Last Post: 12-16-2009, 05:04 PM
  3. Mori SL1
    By jkoper in forum Centroid CNC Control Products
    Last Post: 06-20-2009, 09:13 PM
  4. Mori w/10T
    By grease in forum Fanuc
    Last Post: 10-26-2007, 11:10 PM
