We replaced our hard drive, old one currupted. Had to manually put parameters back in ( user and machine) Need access to spindle parameters but cant find its location.
If you replaced only the hard drive, you should not have to reload any parameters because they are held on the control. The hard drive is merely a backup location for parameters. If anything you should be backing up data to the hard drive, not reloading data from it in this case.
Why do you need the spindle parameters?? Do you have any alarms that you did not mention?
