585,969 active members*
4,461 visitors online*
Results 1 to 9 of 9
    Oct 2010
    Osai A-B 8600
    Hello,
    Does anyone know something about FCRSYS for A-B 8600 Osai. Namely I have a problem to force the machine to load data from Tape reader instead mass storage, since HDD is dead and I have BTR which emulates reader and they says that drip feed works perfectly.
    Thank you in advance
    Oct 2010
    Hi, Do you need a command line in FCRSYS?
    Oct 2010
    Among other things. The command line could be usefull.
    Oct 2010
    Hope it helps
    Loading from Punched Paper Tape Using a Reader
    This procedure requires the activation of the paper tape
    reader driver.
    If the connection is made with the system CPU, write the
    following minimum FCRSYS:
    *2
    XAREAD, 09,0,3
    If the connection is made with the display board, write the
    *2
    XAREAD,09,1,3
    Loading from a Magnetic Cassette
    This procedure requires the activation of the magnetic
    cassette reader driver.
    *2
    XATEAC,OB,0,3
    *2
    XATEAC,OB,1,3
    Oct 2010
    Thank you. It is helpful . Just one more thing! Do you maybe know anything about running a code from punched tape directly since there is only 64 K of user memory and I need even 5 Mb. Thanks, Nebojsa
    Oct 2010
    Try it in FCRSYS
    *4
    /PRO
    /DYO
    IS0
    /PRO is punched tape device
    /DYO and IS0 are optional, I`m not sure.
    Apr 2011
    I need help on the following issue with OSAI 8600 with Herbert Preoptive 8 Lathe.
    I was able to fix some of the hardver problems and startup the OSAI 8600
    controller.
    I am trying to do a "System Clearout"
    which means that some of the memory segments have to be erased.
    I have got the following message during the process
    FILMS1 29 OUT OF MEMORY. this means that " A non existing address has
    been addressed with the DEBUG utility".
    I have typed the correct memory segment (using the manual) and it is giving this
    error message.
    Please help me on this or tell me who can I turn to related to my issue.
    Ferenc
    Aug 2010
    Question I need a help for OSAI 8600
    hello
    We have recently bought Utas ( Osai A-B 8600 Control )cnc turning Machine with an OSAI – Allen Bradley 8600 control system. This unit when purchased by us was not working
    We are kindly request help in guiding us to sort out the below mentioned problem.( We change the battery cause the one we get it in the control was totaly Empty)
    When the machine is powered on the following messages are shown on the screen:
    SERIES 8600 o.s ver 4.0
    DISC????
    BUBBLE????
    CMOS????
    EPROM????
    ***INIT ABORTED***
    thank you for responding
    Many Thanks in advance,
    Regards
    mohammadreza dolatabady
    Apr 2011
    19
    8600 tape loading
    As standard the 8600 can load memory from tape but cannot run from tape directly. If you have a BTR unit then that is not OSAI system so I'm afraid you are on your own. OSAI can supply HDU system.
  1. Osai 8600
    By PaulWCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-11-2019, 06:52 AM
  2. Osai A-B 8600
    By karmoleed in forum European Club House
    Last Post: 10-07-2012, 10:08 PM
  3. OSAI A-B 8600 SOFTWARE
    By baba1511 in forum European Club House
    Last Post: 01-11-2012, 07:29 AM
  4. CNC Series 8600 ''Init Aborted
    Last Post: 01-28-2010, 01:32 AM
  5. OSAI A-B 8600 SOFTWARE
    By baba1511 in forum Community Club House
    Last Post: 10-21-2008, 05:37 PM
