585,568 active members*
3,534 visitors online*
Results 1 to 10 of 10
    Oct 2010
    What RPM to run at?
    I'm cutting a slot into A2 steel using a 7/64" end mill. The end mill is carbide, as it is the only one that had the cutting depth I need. I have a 2 flute bit and a 4 flute bit. I was wondering what RPM I should run this 7/64" end mill at for cutting into A2? And also, what should my depth of cut be on each pass I make cutting the slot? I normally use 4 flute end mills, but would the 2 flute be better for this? Thanks!
    I should add that I am using a manual mill for this slot, not a cnc.
    Jan 2009
    24
    A2 cutting
    I would start out around 750 rpm with the 2 flute carbide cutter and make sure that you flood it with coolant. Take about .03 deep per pass. See how it is acting and adjust your feed and speed accordingly. At least you are not cutting D2. Hope this helps
    Jan 2010
    485
    Are you "chain drilling" a row of holes first? This is a big help in removing stock faster, leaving less material to remove with the end mill. Use a drill that leaves 0.020 - 0.030" per side for the mill.
    cary
    Oct 2010
    Quote Originally Posted by packrat View Post
    cary
    That's a great idea. I've done that before, don't know why I didn't think of it. Thanks!
    Oct 2010
    So I did the chain drilling, and was running at 800 rpm with a .01 DOC, and just broke my second end mill. .03 seemed like a lot to take off per pass. Is there something I should change?
    Sep 2007
    359
    neoga34
    HSS would be best for interrupted cuts
    But to use carbide i would plunge cut and just take it at 10 to 20 thou
    Oct 2010
    Quote Originally Posted by M250cnc View Post
    neoga34
    Thanks I'll try that. I would prefer HSS, but they don't make an end mill this size with enough DOC in HSS, only carbide. I'd have to mill half the slot, then flip the piece over and mill the other half. It's kind of a precision piece, so I didn't want to do that.
    Sep 2007
    359
    I would also check the speed as i see someone recommended 750
    I am not familiar with the grade D2 but with 7% carbon steel it gives an rpm of 3800 at 2" IPM you may be able to go faster as i have set my max spindle speed to 3800 in the cam software.
    HTH
    Oct 2010
    Quote Originally Posted by neoga34 View Post
    This worked like a champ, thanks again. Yeah the speed was a little slow, I bumped it up to 1000 rpm and that seemed to work well.
    Sep 2007
    359
    Hi, glad to have been able to help
    Sent from my HTC Desire using Tapatalk
