585,949 active members*
4,181 visitors online*
Results 1 to 15 of 15
    Mar 2010
    Exclamation Mach3 Slave Axis problem
    Hi, Need some help please!
    I have two steppers that drive my X Axis; I would like to wire them up to my controller card so that they are both on separate outputs. I have wired the second stepper up and made it axis A and salved it off of , so far and it moves in both directions fine. The problem is when I home the machine it’s as if when it gets to X that both motors are trying to go in different directions.
    The controller card is a basic C10 Breakout card.
    Any ideas?
    I have tried to attach the Mach3 machine set up with no joy, if anyone is keen to give me some advice that would be much appreciated.
    Cheers
    D
    I've answered this 3 times this week.
    If you have only one home switch, in general config, Check the box labeled "Home Slave with Master Axis".
    If both the master and slave have their own switches, then you probably need to reverse the homing direction of the one axis in Config>Homing/Limits. Use the Home Neg. column.
    May 2009
    264
    What Gerry said....
    See the image below from the Mach3 Homing and Soft Limits screen. Just check or uncheck the A-Axis home neg and it'll go in the right direction.
    Mar 2010
    Hi
    Thank you both i will try this tonight and post results
    Thanks again
    Darian
    Mar 2010
    Hi
    I tried the A - Axis home negitive with no result. steppers tried to go in differant directions (well it seems like it)
    I also tried to find the "home slave with master axis" undar genral config with no joy what so ever the version of Mach 3 i have is 1.83.027 im guessing that feature is in a more recent version?
    You are correct i only have one home switch on the X-Axis.
    more help welcome
    Cheers and thanks
    D
    With that old version of Mach3 you'll need two switches, one on each side.
    Mar 2010
    Hi
    Got new version and did as posts instructed, Thanks very much guys big help
    D
    Aug 2008
    1166
    If you can, I'd recommend adding a home switch so you have one on both sides of the gantry. Then you'll square the gantry when you home it. I know I've had times when I stalled one x motor but not the other and the gantry was definitely not square. With dual home switches I could fix that very quickly.
    CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
    Oct 2013
    20
    Re: Mach3 Slave Axis problem
    I know this is an old thread. But issue is related.
    I have latest build of Mach3, 2010 screen-set. A slaved to X. Homing in General config set 'home slave with master'. Everything goes in correct direction
    If I set both axis to match X (at home). 2 x credit cards. Jog away and then home. X is 2 x credit cards, Y is 1 or slightly less. I have triple checked play on both axis (ball-screws). Ball-screw nut is tight. Ball-screw nut locked and tight. Play in end bearings. Disconnected motors and re-tuned.
    I'm at a loss. Any insights appreciated.
    Gordon.
    I have no idea what you're trying to say?
    Aug 2008
    1166
    I think he's saying he's gaging the distance of his gantry from his home switches with a credit card, and after homing both sides to square the gantry one side is one credit card thickness from its home switch and the other side is two credit card thicknesses from its home stop. In other words something messed up during the homing procedure and the gantry isn't square. Or I could be wrong.
    Oct 2013
    20
    Almost correct, except, gap where home switch is 2 cards. Other side (no switch) gap gets smaller. And will eventually hit frame. If I don't sqaure it.
    I guess another switch is the answer. If I do that, do I change homing to RefCombination(9) (both X and A at same time?
    Gordon.
    If you only have one switch, Mach3 won't square the gantry. If the two sides are moving different amounts, then make sure the homing speed for both axis is the same.
    If they are the same, and it's going out of square while homing, then yes, two switches should help. And yes, with two switches,, use RefCombination.
    Are you using the parallel port, or a motion controller?
    Oct 2013
    20
    Motion Controller. UC100
    It's very possible that the motion controller plugin is causing the problem, as the motion controller is what handles the homing.
  1. G540 + Mach3 Slave Y & X axis
    By dglasco in forum Gecko Drives
    Last Post: 09-28-2013, 10:23 PM
  2. homing problem in Mach3 with slave axes
    By nicubila in forum DIY CNC Router Table Machines
    Last Post: 04-03-2013, 03:15 PM
  3. Problem with X and A slave axis
    By deemon328 in forum Uncategorised WoodWorking Machines
    Last Post: 09-02-2010, 07:00 PM
  4. Replies: 8
    Last Post: 10-29-2009, 02:09 PM
  5. Slave axis problem
    By Curtis Erpeldin in forum DIY CNC Router Table Machines
    Last Post: 07-30-2008, 08:57 AM
