hi
i need a help in calculating correct tooth thickness for involute external spur gear
gear data is
No of teeth =45
normal module =1.5
pressure angle =20 deg
Tip Diameter =69.800 mm
Root Diameter =65.800 mm
Pitch Circle Diameter(PCD) =67.5
Distance between the pins =70.750
Diameter of Pin =2.000mm
Addendum Modification coefficient =0.5
from set of engineering calculation i have done gear but toot thickness is not correctly matching with customers output
my tooth thickness came =3.08616
customer tooth thick = 2.9899
please help me for this. i have not used addendum modification coefficient in calculation.if need to use how to use that?
