Hello , I have a HAAS VF1_D (10k spindle, no gear box ) model with around 4000 hours on the spindle. The spindle runs very quiet threw all RPMS Just had the main spindle motor rebuilt due to the bearings going out.
Ok machine has been running fine for the last year however when you are doing a pocket cut ( in steel) and you start to get in deep with the cutter and get to the outer edge of the pocket and start to grind some chips you will hear a loud grinding noise coming from the shroud area of the spindle . The noise only happens when you start cutting chips. I have tried different tool paths, step over, depth of cut, 2 or 4 flute cutters and positioning my coolant to flush out chip better. However you can only minimize some with this, it's still very noticeable . The finishes still looks great and the machine is holding good tolerance. I just don't recall hearing this noise on any other VMC I have ran in our shop ( all HAAS). Is this something I should be worried about ? If so any ideas of what it might be ?
