585,764 active members*
4,347 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > Looking for open source or free CAM software that support 4 axis machine
Results 1 to 10 of 10
    Nov 2010
    Hi, any please recommend some of it, it will great if it can run on linux,
    i looking for a while, but found nothing
    Jun 2005
    138
    KCam, EMC2, Mach3, TurboCNC,and other CNC related software links. about half way down the page.
    I use Google Sketchup for the CAD and the PhlatScript plugin for G-code generation, then Mach3 for the CNC control, but I'm running a WinXP machine.
    Nov 2010
    thank Dorsal, but i can't see any program that can support my 4 axis cnc for free especially on linux
    Jan 2004
    3154
    Pencil, paper and calculator is about all you will do for free.
    www.integratedmechanical.ca
    Jun 2005
    138
    EMC2 - "It can simultaneously move up to 9 axes and supports a variety of interfaces."
    How much more confirmation do you want? LinuxCNC.org - About
    Nov 2010
    Thank, DareBee
    I think that way should require some brain and a lot of knowledge
    Mar 2010
    162
    Quote Originally Posted by Dorsal View Post
    That's not CAM software. CAM software generates G-Code.
    Jun 2005
    138
    Quote Originally Posted by Matt Clara View Post
    Let's look at this another way; There are either of two possibilities here, and I'll leave it to you to calculate the probabilities of each, to lead you to the solution of your quest:
    1) You are the FIRST person in the WORLD who ever tried to run a CNC from a Linux machine and it's never been done yet
    - - - OR - -
    2) You have already been provided the answer but are unwilling to read or incapable of understanding the functionality of the software the REST OF THE LINUX WORLD has been using since long before you were born.
    (wedge)
    Mar 2010
    162
    - - - OR - -
    (wedge)
    A) I didn't ask the question; and,
    B) He doesn't appear to be asking about the controller software--he specifically says CAM software, and EMC2 is not CAM software, it's controller software.
    linux cad cam heekscnc - Project Hosting on Google Code
    its not 4 axis but hopefully it gets you that much closer to what your looking for
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  1. Open-source foam cutting software for XP.
    By moreil in forum CNC Wire Foam Cutter Machines
    Last Post: 08-27-2009, 04:02 PM
  2. Blender 3D CAD, Freeware, Open Source Software
    By der_fisherman in forum Uncategorised CAD Discussion
    Last Post: 06-04-2009, 04:58 PM
  3. Building and Open Source CNC Milling Machine
    By hesham morsy in forum Vertical Mill, Lathe Project Log
    Last Post: 09-23-2008, 08:13 PM
  4. electronics software ( open source/ free)
    By visky in forum OpenSource Software
    Last Post: 08-15-2008, 09:53 AM
  5. open source cnc machine plans
    By Bill Davis in forum Stepper Motors / Drives
    Last Post: 07-28-2006, 06:20 PM
