585,754 active members*
3,960 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor?
    Jan 2009
    245
    Figured I would start a new thread, as the old one was somewhat off track.
    This is what I find in the ladder, and by on and off, I mean on is lighted up as white, and off is just regular green.
    R102.0 ALARM ON
    R283.0 HYD PRESS NORMAL off
    R283.1 HYD PRESS ABNORM off
    R283.2 AIR PRESS NORM off
    R283.3 AIR PRESS ABNORM off
    R283.6 LACK OF LUBE off
    R400.0 MOTORS ALARM off
    R400.1 BREAKERS TRIPPED off
    R400.2 SP MOTOR ALM off
    R400.3 AXIS TORQUE ALM ON
    R400.4 PRESSURE ALM off
    R400.5 LACK OF LUBE off
    R400.6 Q-SETTER ALM off
    R400.7 TOOLS USED UP off
    R401.0 MEM X AXIS TORQUE ALM Off
    R401.1 MEM Z AXIS ALM ON
    R401.2 CENTRE ALM off
    What shall I do now, I have changed the Z axis drive and the drive motor. What should I look for now? I am also getting a Z axis slow limit switch error. I have checked the switch, with a continuity tester, and checked the terminals at the switch, and that all checks out, but I cannot clear that alarm either. Anyone know where to check now?
    Here are some photos of the ladder
    Here is also a vid of the ladder, notice how they go from on and off really fast?
    [nomedia="http://www.youtube.com/watch?v=V-1qlI2Fhm0"]YouTube - MVI_0457.AVI[/nomedia]
    Sep 2010
    125
    just look on your ladder, you might have somewhere on the line of the coil of R401.1 , a keep relay and you need to set it to zero manualy .
    It is a safety system frequently used on wasino lathe and lot of others MTB .
    Hello,
    Did you ever got the machine working? I have
    The same machine, lost parameters. Found all
    the info you posted and put it un my machine
    Only to find myself exactly with the same alarms
    alarm MEMORY OF Z AXIS TORQUE ABNORMAL R401.1
    Also R400.3 which only Tells you There is the
    torque alarm but more the axis, and the
    Lubrication alarm, R400.5
    What did you do to get it working?
    jolulank
    My email address [email protected]
    UOTE=tmbruno28;848688]just look on your ladder, you might have somewhere on the line of the coil of R401.1 , a keep relay and you need to set it to zero manualy .
    It is a safety system frequently used on wasino lathe and lot of others MTB .[/QUOTE]
    www.doctornumerico.com
    cnc physicians
  1. Mazak QT 15 Alarm 14 Drive alarm z axis
    By Rodent73 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2013, 01:21 PM
  2. Chiron X Axis Torque Alarm 409
    By Laig in forum Uncategorised MetalWorking Machines
    Last Post: 01-27-2012, 03:54 PM
  3. Alarm 409-servo alarm- z axis torque alm
    By jessebpm in forum Hyundai Kia
    Last Post: 06-15-2010, 01:45 AM
  4. X axis torque alarm on Takisawa Lathe
    By lkenney in forum MetalWork Discussion
    Last Post: 08-27-2009, 08:14 PM
  5. Fanuc 10tf Alarm
    By L. Sakthivel in forum Fanuc
    Last Post: 05-30-2007, 04:49 AM
