hello all im currently uing a kia superturn 28 with a fanuc controller and ive run into a problem regarding trying to cut an inverse angle using a g71 canned cycle. for ex (cutting / as opposed to \). first ill show you my trial program then explain what it is doing.
N1;
G40;
G28 U0;
G0 T0101;
G50 S1500;
G96 S400 M3;
G0 X5.1 Z0.05 M8;
G71 U0.075 R0.01;
G71 P101 Q102 U.01 F.01;
N101 G0 X4.98;
G01 G42 Z0.0;
G03 X5.0 Z-0.01 R.01;
G01 Z-0.125;
X4.0 Z-4.0;
X5.1;
N102 G0 G40 Z0.05
X10.0 Z10.0
G28 U0;
M0;
Basically instead of breaking up the machining of this piece up into the depth of cut specified (0.075) it tries to cut the whole angle at once. I had someone tell me to add a Z0.05 on the N101 line and removing the Z on the N102 line he got it to work on his machine. he was using a HASS. i tried that myself but i kept getting an illegal g code alarm. if anyone knows how to accomplish this on a kia it would be greatly appreciated. as of now i use that canned cycle but manually change the offset on the X geometry of the tool being used and make my own depth of cuts. on smaller pieces i use a g72 canned cycle with a groove tool to do such an angle. there must be a way to get a turn tool to do this on my kia. any insight on this matter would be greatly appreciated.
