585,589 active members*
2,918 visitors online*
Thread: ESP Forest
    Nov 2010
    ESP Forest
    Can someone please help me get a schematic for an ESP Forest? I only need the general body measurements and shape. Any help would be greatly appreciated!!! Thanks
    Feb 2009
    202
    Are you looking to make this guitar by hand or on a cnc router? I have created models for basses/guitars and then sent the end user a 100% true scale pdf of the guitar cut into fours pieces. They then set their printer settings to true scale, print the four sheets and use register marks to create a template that they can trace on wood and then cut out by hand. Also have done it by 3D model programmed for cnc machining.
    Feb 2005
    168
    Quote Originally Posted by DIFF OVER View Post
    Wow thanks for that I was just thinking about where I can obtain these kind of plans :cheers:Can I PM you as to what you have ? Also how much would they be or are they free ? just need to know for sure :cheers:
    Mar 2007
    21
    ESP Forest
    I attached a model of the ESP Forest from the Google Sketchup Warehouse (done by someone called Kaleb)- you can download it for free. I converted it to DXF(lines only) so you can get the outline and dimensions.
    Its not to scale though, but you can scale it yourself : the Forest's nut width should be 42mm its scale length 648 mm.
    Nathan
    Attached Files Attached Files
  1. Looking for Forest Edwards Twin plans
    By sdjdave in forum I.C. Engines
    Last Post: 10-30-2005, 11:30 PM
