585,922 active members*
3,677 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > PicStep Moves While Router Running Problem SORTED
    Aug 2007
    22
    Sorry its been so long since i last posted ;-) To busy cutting things out. I had a job for a school. Knowing that sometimes i would loose my Zero Setting due to interference. It was only caused while using a router or something that sparks a lot on the comutator. Most other jobs i have been using i high speed drill which did not give me problems. After i screwed up the job i had to fix it and sort out the missing steps. Been in the tv repair business i started tracing the fault. 1st i twisted the bi-polar wires to the motor. No Better 2 cut out a complete filter circuit from a Sony TV & placed inline with my supply. No Better, 3 Earthed the Machine,PC & Control Board, No Better, Last ;-) 2 x 10 nf caps 1 on the input & 1 on the step control of the Picstep Boards DOWN TO GROUND. I hope this helps anyone having similar problems. Now I can frigging use my welding machine on the same supply and my motors DO NOT MOVE EVEN 1 STEP. Good luck all.
    Jun 2006
    4
    Thanks for the tips!
    Apr 2005
    253
    Worked for me
    I'll get it finished sometime after I start it.....
  1. AXYZ Router Slow on Z moves: Why?
    By peetle in forum Commercial CNC Wood Routers
    Last Post: 04-15-2010, 03:50 AM
  2. Need Help To Get My Router Up & Running
    By jazz352060 in forum Open Source CNC Machine Designs
    Last Post: 02-17-2010, 11:05 PM
  3. Getting my Router up and running
    By fuelsguy in forum CNC Wood Router Project Log
    Last Post: 05-29-2009, 03:59 PM
  4. Mini router up and running
    By chuck99z28 in forum DIY CNC Router Table Machines
    Last Post: 10-26-2008, 02:19 AM
  5. X-axis moves position while running
    By will@djg in forum DNC Problems and Solutions
    Last Post: 10-13-2008, 06:40 AM
