Hello, I have some drivers Fanuc A20b-1003-008 and need data from them, and pin connection scheme, working with +/-10v. or PWM?, thanks.
are you sure of your reference ???? 008 ???
What kind of pcb ?
hello, the drivers you have are A20b-1003-008 and A20b-1004-088
confirm that complete ref is something like A06B-6058-**** , just at the bottom of the amplifier , if it's ok, this are digital amplifier, not analog one, and need to be controled by fanuc digital system
I found the reference is A06B-6058-H006, I need the pin configuration and set points if it's + / -10 v. or PWM, I put a system is not Fanuc CNC
It's not working with +10/-10 Volts, only digital signals.
Not impossible to make it work with another system than Fanuc but very hard !!!
Good luck !!
