585,975 active members*
4,612 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport 560/22 swarf conveyor coollant pump not working? Help needed :)
    May 2010
    Turned on m/c this morning and the coolant overflow warning came up on the screen, turns out the motor isn't kicking in when the float is raised.
    The motor works as flicked the contactor over on the switch and works as should. but won't do it when the float is raised.
    It seems like there is a timer on the float switch that tell the n/c that the float switch has been up for too long. and flashes up 'swarf conveyor coolant overflow'
    Is there a fuse or a relay gone somewhere? was working fine yesterday.
    any help would be great as got so much work to do on it.
    many thanks
    David
    May 2010
    The float switch relay is working as it should. so really unsure as to what the problem is
    May 2010
    does anyone know what parameters that controll of the swarf conveyor and the float switches are?
  1. Replies: 29
    Last Post: 10-08-2014, 08:48 AM
  2. Homebrew swarf air blower & coolant pump
    By guru_florida in forum Benchtop Machines
    Last Post: 05-28-2010, 07:20 PM
  3. What M code for swarf conveyor?
    By cossiegaz in forum Fanuc
    Last Post: 06-04-2009, 12:46 AM
  4. message - swarf conveyor not started -
    By michael88 in forum Fanuc
    Last Post: 11-26-2008, 02:02 AM
  5. Bridgeport Interact 412 CNC pump needed
    By TalonGrip in forum Uncategorised MetalWorking Machines
    Last Post: 09-03-2008, 11:53 PM
