Originally Posted by
feragto
Programimg part is not a problem , I do all what I need in MACH 3 . Can somebody help me with a few suggestions ?
Thanks .
Have you actually carried out industry standard recommended Earth Grounding, Shielding and Bonding recommendations on the system?
I have found most 'noise' problems are caused by the lack of this.
The urge to get a system up and running, usually results in recommended practice going by the wayside.
Fastest1
Is the machine or its frame physically touching the controller and or computer or its case?
The PC is at ground potential anyway VIA the PC. P.S. which is normally common with the earth ground conductor.
The Machine frame should be bonded to earth ground also, when proper bonding is carried out, ground loops are prevented.
Al.
Albert E.
