585,589 active members*
3,745 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > How fast is your homemade CNC?
View Poll Results: How fast can your Homemade CNC cut?
Voters
639. You may not vote on this poll
  • less than 10 IPM (4.2mm/s)
    45 7.04%
  • 10-50 IPM (4.2 - 21 mm/s)
    186 29.11%
  • 50-100 IPM (21-42 mm/s)
    145 22.69%
  • 100 - 300 IPM (42 - 127 mm/s)
    157 24.57%
  • 300 - 600 IPM (127 - 254 mm/s
    54 8.45%
  • faster than 600 IPM (254 mm/s)
    52 8.14%
Page 5 of 5 345
Results 81 to 95 of 95
  1. #81
    Jan 2018
    1516
    Re: How fast is your homemade CNC?
    Not fast enough! 80ipm reliable rapid moves which was a little disappointing. Got some resonance which isn't helping things.
    Only have 3000rpm max spindle so limited to around 20-24ipm cutting with a 8mm 3 flute anyway (esp slotting).
    If it makes any money it'll be spindle and servo upgrades first.
  2. #82
    Mar 2015
    70
    Hi
    I am still thinking, if doing 3 D work , how fast is it possible ?
  3. #83
    Jun 2015
    943
    Quote Originally Posted by shujaa View Post
    Hi
    High acceleration is the important for 3D work. If your machine velocity is fast, but can accelerate the axes up slowly then it will be still slow with 3D work because it can't accelerate up and down in time to reach the programmed feedrates.
  4. #84
    Mar 2015
    70
    SoWell the more is better but for such 3d workwhat should be the target acceleration range.....say 300mm2/min or 600mm2/min...
    Any guidelines keeping in view practicality. Although i would love accelerations of a F1 race car.
  5. #85
    Jan 2018
    1516
    Quote Originally Posted by dazp1976 View Post
    This is where I'm glad I went overboard for Nema34's on my PM25 clone.
    At 400rpm (2000mm/min) the torque figure is almost identical to the Nema23 motor from a similar model line.
    When it comes to acceleration though it's a fairly big difference so far.
    Haven't got round to do that much testing yet with tuning to find it's stall point.
  6. #86
    Aug 2019
    339
    My home shop CNC can cut composites pretty damn fast, its almost scary. I could have a nap between each passes when it cuts ferrous-anything though...
    All depends!
    Should have asked what sort of 'rapids' (aka non-cutting moves) are you getting from your homemade cnc instead
  7. #87
    X 37.5 m/min 0-max in 200mS
    Y 30 m/min 0-max in 200ms
    Z 30 m/min 0-max in 200ms
    X 1.5kw brushless
    Y 0.9kw brushless
    Z 0.9kw brushless
    X1660mm length
    Y820mm lenght
    Z220m lenght
    CNC control RosettaCNC-B 6 axis
    All CNC parts made with mazak center
    Enough fast
  8. #88
    New build for plasma cut:
    X/Y at 88 m/min (brushless)
    Z at 25 m/min (brushless)
    X 12500mm
    Y 2800mm
    Z 270mm
  9. #89
    Jan 2021
    8
    mine can cut at 55 IPM
  10. #90
    Feb 2006
    120
    I converted a colchester clausing mastiff, I had to slow it down, 600 ipm rapids on the x axis is too fast. I limit it to 100 ipm usually to give me half a chance to hit the estop. most of the time that's still too fast for me. I make large parts (3" to 10") and rapids don't save much cycle time.
    Ray,
    Life is a choice, death is choice poorly made.
  11. #91
    Jan 2018
    1516
    A little update.
    Dumped the X,Y nema34 1080oz motors.
    Swapped for nema23 566oz. Kept it as a 60Vdc system.
    Rapids up to 2500mm/min (98ipm), very smooth and it could easily do more.
    Acceleration went up to a setting of 3000 without issue. Seems limitless atm.
    Still not the fastest cutter with it's 3000rpm spindle limit. Should be much better when the servo goes on.
  12. #92
    Faster than 600 IPM (254 mm/s)
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
  13. #93
    I have a belt driven X hub that can cut at 800IPM yet it's really futile at that speed on the grounds that my Y hub max cutting rate is 90IPM. Except if I cut a lot of even notches I never see anyplace close to 800. I leave it set ~120IPM.
  14. #94
    Jul 2005
    37
    Just measured mine, hitting 6000mm/min X & Y 3000mm/min Z
    Not crazy fast, but only has a 200x200 work area.
    Oh, and cuts steel like butter.
  15. #95
    Nov 2012
    1267
    Quote Originally Posted by i_am_fubar View Post
    Got the same speeds on my 200x200 machine. Unfortunately, the only thing it can cut like butter is, well, butter.
Page 5 of 5 345
  1. delrin. how fast is too fast?
    By justanotherguy in forum Glass, Plastic and Stone
    Last Post: 02-24-2011, 04:28 AM
  2. Lazy Cam not posting Fast Travel as Fast Travel
    By astainless in forum Uncategorised CAM Discussion
    Last Post: 02-24-2010, 09:31 PM
  3. homemade cnc
    By taylormade in forum DIY CNC Router Table Machines
    Last Post: 11-26-2008, 01:55 PM
  4. Homemade (diy) CMM arm?
    By hotponyshoes in forum Digitizing and Laser Digitizing
    Last Post: 05-27-2007, 05:25 PM
  5. Homemade THC
    By nerginer in forum Mach Plasma / Laser
    Last Post: 02-23-2007, 10:58 AM
