Quote Originally Posted by linkreincarnate View Post
what are your specs for that machine?
The most up to date specs look something like this:
Footprint (total area it is occupying in the room): 750 x 650mm
Table height from floor: 890mm
Y table size: 450 x 300mm
Weight of Y: 17,5kg
Working area: 310 x 270mm
Weight of X-beam: 13,7kg
Size of the X-beam (height x width): 500 x 540mm
Size of Z: 350 x 150 mm
Weight of Z: 8.5kg
Z clearance from table top: 135mm
Maximum speed: 8000mm/min
Maximum acceleration: 700mm/s/s
Stepper motor data: NEMA23 2.7V/phase, 3A, 1.6uh, 0.9 Ohm/phase
Stepper motor driver: DQ542MA
Stepper drivers PSU: 44VDC unregulated supply, based on a thoroidal transformer
Motion controller: UC300ETH from CNC Drive
Spindle motor: 400Hz, 24,000 RPM 65mm diameter air cooled 1.5kW spindle
Spindle motor power supply: Bosch Rexroth EFC 5610 VFD
Spindle control via Modbus communication
CNC software: UCCNC from CNC Drive
I think the above is pretty accurate. I am making changes all the time since it is a DIY CNC of my own design. Note that axis weights are only approximate (parts measured before installation) and the weight does not include the steppers and wiring.
