I have a Hurco BMC20 Ultimax Control with Fanuc spindle and axis drives/servos. I can not get the spindle to turn on. When I manually turn on the spindle, it shows an RPM for about 5 seconds until it alarms out. I can actually turn the RPM control knob and the RPM on the screen will change until it alarms out. The alarm is "Agree signal failure". I have checked all the cables between the Hurco boards and the Fanuc spindle drive. Also, I have had the Z axis/spindle dual axis board checked and it is in good working order. I have also checked the constant 5 volts to the pulse generator and it also looks good. The incoming 220 volts to the drive checks good. Anyone have an idea what could be wrong??? Pulse generator?? Spindle drive issue??
