585,728 active members*
4,796 visitors online*
    Sep 2010
    16
    Sodick A-280L problem
    My Sodick has a short circuit message when i start to cut, the cables are good and I have 13.8 volts, but it drops to 0 as soon as cutting starts. Any ideas guys?
    Thanks in advance
    May 2009
    31
    My Sodick as well as other EDM machines that I have encountered don't like to have the wire in contact with the work when the juice is turned on; try backing the wire off a bit.
    Dec 2006
    131
    like mark says you need to make sure that the wire isnt touching the part. Make sure your DI levels are good. Hold the calibrate toggle and adjust the needle to 0 with the dial above the calibrate toggle. If it is 5-10 on the scales you should be good.
    Mar 2005
    73
    Re: Sodick A-280L problem
    I am having the same issue. Any luck?
    "Fire is cool" -Beavis
  1. Sodick EX21 CPU problem
    By Jäger in forum EDM Discussion General Topics
    Last Post: 07-27-2015, 06:52 PM
  2. Sodick precision problem
    By Stiga in forum EDM Discussion General Topics
    Last Post: 06-23-2012, 08:41 PM
  3. Sodick DS EDM A3C-R_Power up problem
    By cnchuynh in forum EDM Discussion General Topics
    Last Post: 07-23-2011, 04:51 PM
  4. Problem in Sodick A500 nMark 21
    By puneetchawla in forum EDM Discussion General Topics
    Last Post: 03-02-2011, 12:55 PM
  5. HELP sodick servo problem
    By stuflo in forum EDM Discussion General Topics
    Last Post: 02-23-2011, 11:41 AM
