It works better than I had expected and I grin like a fool every time I use it!
Me too when I run mine! Very nice work. I currently have Kevlar belts on the X and screws on the Y and Z however I'm going to change the Y to belt also like yours. Do you have any problems with the Mach3 safety zones at the extents of your travels ? Mine just slams to a stop only on the X. Also I'd like to see what kind of drive reduction you have on your belt drives. Again, very good job.
Thanks for the comments guys! I used 3:1 gear reduction from the stepper which then drives a pulley along a tightly stretched piece of 3/4 wide belt - works much like rack and pinion.
The attached cad image shows my setup, sorry I don't have a photo at the moment.
SS
Haha, no safety yet! It just slams into stops at the travel limits. I have limit switches but have been too busy making stuff to take the time to install them!
I can't see any means of holding the Z-axis on the rails. Do you have some means to prevent the Z-axis lifting up off the rails?
Secondly, do you need to grind/mill a v-shape on the top of the angle iron to match the v-shape of the truck wheels? It seems to have little contact with the angle iron rail.
Finally, where does one get that aluminum extrusion stuff in Canada?
KOC62
Hey KOC62 and anybody else interested,
If you look closely at the pics, there are aluminum blocks attached to the underside of the 8020 cross members which hold another set of v-bearings against the lower edge of the angle iron. See the image below...
As far as shaping the rails goes, I hand-ground them using a large whetstone, running it back and forth in long, smooth, uniform strokes, at a 45 degree angle. The bearings themselves seem to actually be work-hardening the surface somewhat, they're getting shiny like chrome now after some use. I know that it is not the ideal setup - I would much prefer blocks and rails - but it was pretty cheap to do and the performance is freakin' me out to be honest.
I have machined aluminum on it and the performance is OKAY... a bit of vibration due to 8" travel on my z. If I raise the aluminum up so the head doesn't come down so much, the performance is better. I also have 20 years experience cnc machining aluminum on industrial equipment so my expectations are high. I built this machine for wood and plastics and so far I am a happy camper.
If you are in the Toronto area, 8020 extrusion is available from IPEX Automation in Concord. It works out to roughly $11/foot plus $2/cut. Well worth it to let them cut it, all paired lengths are cut with a stop, so all the pieces matched perfectly. Their Cutoff saw is also built for this stuff, mine, not so much. They also carry a lot of other "fun" stuff. Depending on your budget, this is a place that could be fun for servos and stuff too. All industrial stuff, not so cheap.
We use cookies to optimize our website for you and to be able to improve it continuously. By clicking the "Accept" button, you expressly agree to the use of cookies. For further information on cookies, please refer to our privacy policy.
