585,975 active members*
5,020 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Maxnc CNC mini mill, need help Phoenix, AZ
    Nov 2010
    picked up a used MAxNc a couple of years ago and has sevrved me well for basic engraving but I am limited to the basic font characters that came with the machine. I would like to know if there is a good engraving program available that will work with this unit. The unit is a maxnc 10 open loop system, I would also like to upgrade to a closed loop system and update the computer with something a bit newer than Windows 98. the previous owner already upgraded the motors.
    I have tried to contact MaxNc several times with no luck, I thought I would keep buisness local if I ever needed help or assistance.
    I would also would like to offer engraving for customer supplied artwork something that I could scan and upload to the CNC, I have been told that Corel Draw will work for this application.
    Any help would be greatly appreciated.
    Feb 2007
    4553
    azarmory,
    Do you already have Mach3?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Nov 2010
    Quote Originally Posted by jalessi View Post
    azarmory,
    Jeff...
    not sure, I bought this equipment used, it was basically a plug and play unit. The previous owner gave me a quick run down, showed me how to engrave and I was up and running.
    the way the unit is currently set up is thru Windows 98, I use the engave.exe program, type in what I would like it to engrave and save the file as a .T. I then have to close out Windows and open up DOS, set up the work piece, open up my saved .T file and run the program.
    the only way I am able to change any of the standard fonts built into the engrave.exe program is to manually write my own lines of code and if I want to engrave two lines of text I have to create two seperate lines of text and then copy and paste them into 1 .T file. Even more complicated is attempting to create text in a circular pattern.
    Now I am no CNC wiz but there has got to be an easier way! I have seen several CNC programs available and yes Mach3 was one of them but I have less experiance with what programs will or will not work with my unit. I have been told that CorelDraw will work with being able to scan pictures and converting them to single line drawing and creating a .DXF file for the Maxnc to run?
  1. My MAXNC 15 OL mill and conversion.
    By Fixittt in forum Benchtop Machines
    Last Post: 10-11-2008, 10:21 AM
  2. Sherline/Maxnc or other desktop mill demo videos?
    By david90 in forum Benchtop Machines
    Last Post: 02-16-2008, 04:55 PM
  3. X2 Mini Mill & Mini Lathe - Cummins Tools
    By ccsparky in forum Benchtop Machines
    Last Post: 12-19-2007, 02:54 PM
  4. MaxNC motion kit for Sieg X3 mill?
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 06-16-2004, 06:24 AM
  5. Maxnc Mill
    By Dort in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2004, 04:56 PM
