Originally Posted by
gpk9
Recently purchased this lathe from a friend, manufacturer recommends 5/16" tooling, friend had some 1/4" hss tooling, interested in moving up to 3/8" tooling using TCMT inserts. Wondering if 3/8" tooling would put insert above centerline of workpiece. Anyone know?
3/8" w/qctp is good. With the original turret tool holder, you will probably have to shim to get centered. If the 1/4" tooling required at least 1/8" of shim, you're in the zone. w/qctp, you can run anything up to what the tool holder holds.
Wen I was young, I spent most of my money on fast women, slow horses, and cheap booze. The rest of it I just wasted.
