585,975 active members*
4,531 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > how to turn on spindle while mill spindle is on!!
    Apr 2009
    19
    Hey there guys, Im running a mazak 350 m lathe with live tooling and im trying to run both the mill spindle and the main spindle (in opposite directions) at the same time anyone ever try it. I've heard of it being done before but have had no luck. any help would be appreciated. Thanks
    Dec 2008
    717
    Post some of your program that you are running. That should be a simple move. It doesn't matter which direction the main is going (or the milling spindle for that matter), that is just a C axis move, so nothing really out of the ordinary there...
    Anybody with a milling lathe has tried it...
    Tim
    Feb 2009
    22
    do you have grinder mode - option
    Apr 2009
    19
    Thanks for the response guys but I figured it out soon after I posted there is a simultaneus drill mode in mazatrol it allows you to put in spindle speeds for both the main spindle and the mill spindle! works awesome!
  1. Should spindle turn while M19?
    By chipwitch1 in forum Fadal
    Last Post: 07-06-2010, 03:21 AM
  2. Spindle won't turn on
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 08-30-2009, 12:32 AM
  3. Sweo spindle drive? new mill dead spindle
    By Shizzlemah in forum Fadal
    Last Post: 12-18-2008, 06:11 PM
  4. T1..why does the spindle not turn?
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-06-2008, 03:32 AM
  5. interact 4 spindle drive won't turn on spindle
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 11:51 PM
