I have seen large 5m long belt driven gantrys, my question is where is the best place to buy a large timing/toothed belt? Can it be bought in a roll I can cut to length?
Many thanks
Gav
Many thanks
Gav
I was able to order cut to length belt from a local industrial bearing supplier. Measure your belt carefully, as the same tooth pitch is available in more than one tooth profile, and the belt won't be returnable.
Good luck.
Thanks pro-fab, how long was your belt?
The belts that I am using are 5.5 meters each on the y axis and 9.5 meters on the x axis.
I had a 12 meter belt that I cut in half to replace the ones on the y axis, but although th e sprockets were of the same width and pitch, the profiles were different, and I ended up scrapping the belt.
Hi, I am working on a belt drive diy cnc router. Are you happy with that arrangement ?
BTW, once source for belts is brecoflex, I am sure there are many others.
