Hi all,
We use Mastercam Mill (x4) up here for all our mills, but I have a few Citizen L20's that we use mainly for screws, etc. All of our lathe programming is done manually.
I have an occasional need to mill from the top of the part with interpolation, just as if I were milling on one of our mills, except my values for milling on the Citizen are Y(in Diameter) and Z.
It would be a LOT easier if I could get Mastercam to spit my toolpath out in Y/Z with the G2/G3's setup correctly. I really don't care about any startup or positioning blocks, spindle activation, etc. I just need the actual path itself. Is there any way to do this? Do I need another POST processor or is there a setting I can change? Does anyone have a post processor that does the same as what I'm looking for?
Up until now I've been changing all my values manually if I have something to setup, but it gets really tricky with the G2/G3's sometimes.
Thanks in advance for all responses!
