585,994 active members*
4,788 visitors online*
IndustryArena Forum > Hobby Projects > Musical Instrument Design and Construction > Dimension of switch cavity for back control guitar type
Results 1 to 14 of 14
    Apr 2010
    Can some one give me info for this problem?
    i need dimension,..for 3 ways and 5 ways switch
    and the type of tool for cut this cavity....
    TQ all
    Feb 2005
    168
    Wow did you make that ?
    Apr 2010
    no.I'm trying to modelling a cort x6 guitar....
    its need a switch cavity for 5 way switch,coz it's a back control guitar..can some one help me...
    Apr 2007
    8082
    Try the Lutherie Information Website for CAD files in .zip format. There is a lot of information on that site.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2010
    hohoho....tq carve one...i'll check out that..
    Apr 2007
    8082
    Quote Originally Posted by awe_indo View Post
    There is a switch outline for a 3 or 5 position switch in the ElecPts.zip file, but I don't know if it is the shape you need. I assume that you make the pocket deep enough to insert the switch assembly.
    CarveOne
    CarveOne
    Mar 2009
    5
    TQ all
    Cavity dimension with clearance:
    Length 2.4"
    Width 1.0"
    Deep 1.5"
    Apr 2007
    8082
    Was that switch outline the one that you needed? Just wondering. The dimensions that I see in CAD do not match the dimensions that kimosabi has posted. There may be different sizes and shapes for different manufacturer switches.
    CarveOne
    CarveOne
    Mar 2009
    5
    I mean this switch.
    Apr 2007
    8082
    The CAD drawing shows:
    Width = 0.375"
    Plate length = 1.875"
    Hole spacing = 1.625"
    It looks like it is for the same type of lever switch.
    CarveOne
    CarveOne
    Mar 2009
    5
    Quote Originally Posted by CarveOne View Post
    Width = 0.375"
    Maybe I don't understand what dimensions you mean, but I mean this (see pic).
    All clearances to the switch are ~0,3"
    Apr 2007
    8082
    The CAD drawing is for the switch dimensions, not the pocket dimensions. From that information awe_indo would need to decide the dimensions to make the pocket. One dimension that is not shown in the CAD drawing is the depth of the switch.
    He would need to have one of the switches available to check that this CAD drawing is for the same size switch. This CAD drawing may not be useful to him.
    I have attached a JPG version of the 3 or 5 position switch drawing.
    CarveOne
    CarveOne
    Apr 2010
    it's korean 5 p switch
    I try machine it next week.I let you know if it have an issue...
    But i still confuse with the tool to cut that hole...what size of router bit use to cut that hole?
    Apr 2007
    8082
    I haven't seen any dimensions for the depth of the pocket that the switch is installed into, but the bit needs to be long enough to reach the bottom of the pocket.
    The diameter of the bit needs to be small enough to cut the pocket corner radius that you wish to use. You will need to use a depth of cut that is about 1/2 the cutter diameter. It will take some number of step-downs to reach the bottom of the pocket.
    The feed rate needs to be determined by looking at a feed and speed chart, or by trying different feed rates in scrap wood until you find an acceptable result for the wood that you will be using for the guitar body. It depends a lot on the type of cutter bit you will use.
    If you look for a guitar body drawing that uses this same switch, and find one, you can use the same pocket dimensions from that drawing when you create the gcode. The dimensions that kimosabi provided is a good start and you can modify those if you need to.
    CarveOne
    CarveOne
  1. back up of the machine, having Heidenhein control iTNC 530
    By Abdul Haq in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-03-2010, 05:17 AM
  2. Back up parameter list 3t control
    By david2259 in forum Fanuc
    Last Post: 04-06-2010, 10:41 PM
  3. RFQ-control plate for a lap steel guitar
    By buckkillr8 in forum Employment Opportunity
    Last Post: 06-09-2008, 02:40 AM
  4. MICRO Adjustment of Lever Type Limit Switch
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 05-16-2007, 02:47 PM
