585,591 active members*
3,013 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Motor just stalls and vibrates!
Results 1 to 13 of 13
    May 2010
    146
    Im using the 400 ozin motors and Probostep drives from probotix. Im trying to turn a 1/2-10 lead screw with a 4:1(ish) gear ratio. a 42 tooth pulley at the motor 11 tooth at the screw. The screw turns prertty freely but it seems no matter what speed/ step combo I try it stalls out. if you want to see the machine its on my build thread is here
    http://www.cnczone.com/forums/diy-cn...tml#post857828
    ideas? Id hate to think that a 400ozin motor really couldnt turn this screw but I guess its possible.
    Oct 2006
    975
    Hello,
    Does the motor work correctly with the belt removed? I guess your are speaking about the X axis but have you tried any of the other motors/axis?
    Regards,
    Wes
    May 2010
    146
    The motor works fine with the belt removed. Ice tried different combinations of micro stepping
    from 16th to full. Things seem to work better the closer to full step I get but go back to the same issue as speed picks up.
    Oct 2006
    975
    In Mach are you using the settings for the motor tuning that are recommended by Probotics? On my small CNC build for my X axis I went from an old stepper to a newer 425oz.in. stepper which helped but I needed to play with the motor tuning settings to get it to work well with the heavy worktable I am using.
    What are you using for the Step Pulse and Dir Pulse in motor tuning?
    With the belt disconnected can you push the axis easily in each direction by hand, or do you feel a bind or restriction when you try to move it?
    Regards,
    Wes
    May 2010
    146
    I'm actually using EMC2. That's what Probotix recommended
    But they don't have recommended specs I was using 1/16th step with 3200 steps per in and micro stepping set to one.
    Oct 2006
    975
    I'm sorry, I have not used EMC2 and don't know anything about how it works or how to configure it for motors. My fault for assuming Mach was the controller.
    You might take a look in EMC2 and see if you can find Motor tuning or another application to help get the motors setup correctly. Mach3 has an axis calibration application that makes it easy to get the motors set up and calibrated. Hopefully someone with EMC2 experience will reply and give you some good help.
    Regards,
    Wes
    May 2010
    313
    Quote Originally Posted by prcdslnc13 View Post
    is it me? or do you have the gearing backwards?
    May 2010
    146
    Yes in the pictures it is. Its right now. I was using spare parts before. Every thing is right now.
    Sep 2008
    34
    What size power supply are you using? I would have at least a 32 Volt.
    15362
    prcdslnc13
    I just looked a your photos & read a little more, you don't have a low enough gearing for the motor to drive it, on your
    1 turn & it moves 2", you will need to get it some were near 10 or more turns of the motor to the 2" of travel, You may need even more than 20 turns of the motor for the 2" of travel, it will depend how much load it is trying to move
    WoodSpinner
    I saw that to in Post # 1, but I then looked at the photos, & they look to be the right way, but if he does have them the way that's in Post #1 then they would be the wrong way
    Mactec54
    May 2010
    313
    Another thought, 1/16 stepping is the weakest possible setting.
    John
    May 2010
    146
    I did eventually get it all moving tonight. I think you guys are right, I have my gearing wayy too low. I did it that way hoping to get a little more speed out of it, but I think Im going to have to bite the bullet and give up some more space in the garage to direct drive the screw.
    Right now I just am not getting into the torque band enough to really move anything. When I got it moving I was set to 8th step at about 1ips and acceleration at 27ips.
    I was able to cut my first part at that speed, but I have quite a bit of backlash in it, Im guessing from the belt also, So one more part to cut and the belts probably going.
    15362
    prcdslnc13
    I thought you were having trouble with the Y axes,(your chain drive) yes on your screws you could try doing them 1.1, if your belt has the right tension then you won't have a back lash problem, unless the belt drive components are not strong enough for the job
    Mactec54
  1. X2 motor stalls after tapered roller bearing conversion.
    By TXFred in forum Benchtop Machines
    Last Post: 10-13-2010, 07:44 PM
  2. stepper stalls out
    By edgara in forum DNC Problems and Solutions
    Last Post: 10-12-2010, 05:53 AM
  3. program stalls on M10
    By firekoe in forum Fanuc
    Last Post: 04-16-2010, 03:28 PM
  4. Replies: 0
    Last Post: 07-01-2007, 02:15 AM
  5. Spindle Stalls Out
    By blay in forum Milltronics
    Last Post: 05-03-2007, 10:55 PM
