Hello,
I am thinking of buying a JCUT 6090 router machine for my home shop. It will be used for hobby work, but will also have to be strong enough to do serious work once in a while.
I will mainly use it for wood - pine, walnut, oak, poplar..., but sometimes it will be used for light aluminum and plastic.
On Ebay, I see that the 6090a with the 1.7KW spindle costs about $2888.00. How much more for the 2.2KW spindle?
I have read something here of the 6090b. Can you explain the difference between the 6090a and the 6090b? Is the price the same? If not, why?
Will these machines run on 240 volt 60 hertz. I would only be able to supply single phase from my home.
I have seen some examples of items cut on the JCUT 6090a. I was impressed. It looks like it can handle 3D shapes and do a good job on them.
Thank you in advance,
Butterknife
