585,937 active members*
3,944 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > warmup program: dwell time is incorrect if set > 60 seconds
Results 1 to 12 of 12
    Dec 2005
    183
    Hey all,
    My warmup program (VF1) specifies a dwell of 300. seconds per RPM setting, but it only runs for about 45 seconds. I played around with a bunch of values. Any value less than 60. produces the correct dwell time. However, anything above 60. produces an apparently random dwell time...but always less than 60 seconds. Thoughts?
    Oh and my program is identical to my neighbor's VF3, which works fine.
    2932
    Are you always specifying P with a decimal point? With a decimal point, P is seconds, without a decimal point, it's milliseconds.
    Dec 2005
    183
    Yes,
    S500 M03 P300.;
    Apr 2006
    235
    I think you have to add a G04 for the dwell command followed by the P command for the length time.
    On the default warm up program it's something like
    S500 M3;
    G04 P1000.;
    . . . once I forgot the decimal point and had a pretty good scare when the rpm suddenly ramped up when I wasn't expecting it. . .
    Feb 2008
    586
    Not familiar with Haas. I do know on some machines, if you're in IPR, then dwell is in revolutions, not seconds or milliseconds, and if you're in IPM, then it's seconds
    Jul 2010
    369
    Yes... I have to Input a G04 and a decimal point after the dwell amount to get my Hass to do right.
    Dec 2005
    183
    Sorry I misstyped I have: S500 M03 G04 P300. I don't think it's ipr because if I input P60. It runs for 60 seconds but if I input P70. It runs for about 12 seconds.
    Aug 2010
    579
    Earlier Haas software versions had a problem when dwelling over 60 seconds. To overcome this, order a new machine..... Or, you can program a 300 second dwell using multiple lines; like this:
    G04 P60.
    G04 P60.
    G04 P60.
    G04 P60.
    G04 P60.
    Ken Foulks
    Dec 2005
    183
    Okay, just tried a test and here are the results:
    P30. = 30 sec
    P60. = 60 sec
    P100. = 34 sec
    P300. = 37 sec
    Mysterious for sure.
    Aug 2010
    579
    What software version do you have, if you have 3 or above, it can be fixed with a software update.
    (Fixed in SW version 3.16)
    Ken Foulks
    Dec 2005
    183
    I have version 3.9
    Aug 2010
    579
    You can upgrade by contacting your HFO, they will replace the processor.
    Ken Foulks
  1. fanuc 10m dwell time
    By skippyfix in forum Fanuc
    Last Post: 09-03-2011, 04:25 PM
  2. Mach3 Compatible Axis Warmup Program
    By Phife in forum Mach Software (ArtSoft software)
    Last Post: 01-16-2010, 04:39 AM
  3. Warmup Program Gcode
    By Phife in forum DIY CNC Router Table Machines
    Last Post: 01-09-2010, 02:45 AM
  4. Dwell time
    By GBRAVO in forum I.C. Engines
    Last Post: 06-10-2009, 08:19 AM
  5. cycle time macro program
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2006, 07:33 PM
