585,908 active members*
3,660 visitors online*
Results 1 to 7 of 7
    Mar 2007
    52
    Fanuc 21t Tooling Setup Procedure for 2axis lathe
    Hi Everyone
    Im looking to find out if anyone can explain how to setup tools on this type of lathe. I am just learning to operate this machine and wanted to know if there are any resources for this(as the manual I have is not the greatest). Or if someone can walk me through it. I understand how to operate and setup a cnc milling machine and have built my own cnc router. But for some reason I can''t get a grasp on the lathe for setup.
    Like it says in the title its a fanuc 21t controller on a 2 axis monarch lathe.
    Any help would be appreciated.
    Jun 2005
    232
    Tool seting fanuc 21
    To set work shift
    move the tool to to your zero point( touch off tool 1 in program)
    press off set key
    press right arrow soft key TWICE( the soft keys are under the screen
    there are no markings on them)
    on the bottom of the screen you will see (w shift) press the soft key under it you should now be in the workshift page.
    Upper left hand corner of of work shift screen the is x and z
    highlight the Z press 0 input ( change the number to 0)
    on the bottom right of the screen there is a number z xxxxx(relative)
    enter that number as a NEGATIVE number in the upper left (where you just changed it to zero )
    Now that bottom right number should read zero and your workshift is set.
    To set tool length offsets
    index to second tool in program(example tool 2)
    touch off tool
    go to the geomertry screen highlight z in tool 2
    push off set Measure key (this is not the same key as off set key)
    press Z0
    push measure (soft key under screen)
    To set diameter offsets
    Take a cut with the tool you want to set ,(ex tool 2 )move the tool off the work buy moving z axis.
    stop spindle
    measure workpiece
    go to geomerty screen Highlight x tool 2
    press offset measure key (this is not the same key as off set key)
    type x and the diameter size (example X1.625)
    press measure (soft key under screen)
    Tim
    Mar 2007
    52
    Hi Tim
    Thanks for the reply. I tried out your procedure and got my tooling set. It made sense once I started through what your wrote.
    One other question. How would you set up drills and taps?
    Jun 2005
    232
    Drills and taps are set at x0 Tram your drill holder get it exatly centered push measure key type in x0 then press measure key .
    example to drill a 1 inch hole 2 inchs deep
    T0101(1 INCH DRILL)
    S750M3
    G0X0Z.1
    G1Z-2F.005
    G0Z1
    If your tapping in your lathe you need a tension and compresion tap holder. It lets the tap float a little because your spindle
    will not stop exactly the same time as the z axis will .
    Hope this helps
    Tim
    Tim
    Mar 2007
    52
    Tim
    Thanks for the reply. This may be a stupid question but how do you find the centre? I understand setting X to 0. And touching off the end of the part for the other Z0. However how do you know you are exactly at the centre for the X.
    Jun 2005
    232
    Put an indicator in the chuck tram the inside of the drill holder move x using the mpg until it is centered and that will be X0 for your drill.
    Tim
    Mar 2007
    52
    work shift
    Ok I think im getting the hang of the work shift ??? And setting tool lengths. However in the g-code what specific things do I need to make sure are in it. With the work shift do I need to call up a G54? Do I need to set the work shift for every tool or does doing the offset for each tool take care of that and the work shift is only for the touch off tool. Then use a specific g-code.
    If someone can provide some simple sample code and just give a run down of it that would be great for starters.
    All the best
  1. Machine parameter edit procedure for FANUC 6T System
    By VENKATESH REDDY in forum Fanuc
    Last Post: 10-13-2011, 10:56 PM
  2. Procedure for moving off hard stop ( Lathe)
    By chipsahoy in forum Fanuc
    Last Post: 03-02-2010, 11:19 PM
  3. Fanuc 3M start up procedure
    By Gunner52 in forum Fanuc
    Last Post: 03-01-2009, 10:35 PM
  4. Mazatrol T1 Setup Procedure
    By mattme in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2007, 07:24 AM
  5. looking for easy to lurn 2axis lathe software
    By mike10 in forum Uncategorised CAM Discussion
    Last Post: 09-13-2006, 07:56 PM
