I Just picked up a Hardinge Superslant with the GN6t control. I powered up the machine, Released the e-stop buton, The control goes through the boot but stops before showing the position page.
When i press the emergency reset button the x axis brake releases and the x starts to slowly drop but the hydraulics and the drives don't kick in. The pil light is on, there is 5v, 15v, and 24v @ the power supply but not at the check pins on the main pcb. there are no lights on the main pcb.
The crt shows alarm flashing in the lower right corner, and 1000 emergency stop not ready
The axis seem plenty far away from any of the ends of travel. I did not see the machine run before I got it, but was told it did run ( I know, we've all heard that before!)
Can someone please help?
