586,000 active members*
4,862 visitors online*
    Dec 2010
    2006 shopsabre
    Im new to cnc. Looking at a 2006 4896. no vacumn, it has atc.
    it has rotary lathe attachment. owner says 200 hr or so. 5 hp spindle. Is $20000 a good deal
    Nov 2007
    2466
    go see it work and listen to the spindle at 15000 rpm (with no bit in collet) for a 1/2 hour or so it will be reasonably quiet and smooth if it sounds loud or rough it could need rebuilding, the rest of the machine (as long as it did not fall off a truck) is probably ok, call pds columbo in NC. or hsd in florida, they can tell you the price of a new spindle if needed. call shopsabre they should know some history on the machine, with an atc 16-22.000 is not unreasonable, if the spindle is iffy then the price drops
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com http://dropc.am/p/EJaKyl
    Apr 2008
    46
    used CNC
    I would be careful on a used CNC unless you are intimately familiar with them. There are many things that can affect how they run, and many of the tolerances are codependent. I would check with ShopSabre to be sure they will support the machine first, then I would run some tests with the machine to ensure tolerances are good (tight circles and some z tests). I bought a "demo" machine from ShopSabre, warranted as new, and after several months of trying to get it to work, they replaced it with a new one (which says a lot about them, and the machine has been solid as a rock).
    Good luck
  1. Propellers on a Shopsabre
    By Piet propeller in forum Shopsabre
    Last Post: 03-16-2022, 06:27 AM
  2. ShopSabre replacement
    By rgh in forum Shopsabre
    Last Post: 04-16-2009, 11:10 PM
  3. New shopsabre
    By BensMillwork in forum Shopsabre
    Last Post: 01-17-2009, 06:35 PM
  4. 4th axis on Shopsabre
    By trevis1st in forum Commercial CNC Wood Routers
    Last Post: 09-14-2008, 01:47 AM
