Hello
for now I can't replace because I have no similar current sensor in stock, I ordered several from China and when I receive will replace... I set parameters as you proposed in some posts here. This problem can't be due wrong parameters,current sensor just failed due some internal reason, it has electronics inside and gives voltage output. If some parameter was wrong IGBT would be blown,or input rectifier,this sensor can measure up to 80A
