585,992 active members*
5,344 visitors online*
    Jul 2006
    83
    Raster engraving a vector drawing
    OK forgive me if I misstate some things, but I was wondering if you could select only the lines when you raster engrave & not the spaces between the lines ( or is that called engraving on low power ) . I did some tempered glass and used cut at about 30s/15 p ( 100 w), and it looked like a almost joined dashes. It actually looked good, but then I rastered the same image (600 s/15 p ) and it took probably 30 mins. JUst in thinking about the process if it only rastered the lines not the spaces it would still have to cover the same area of material and take just as long. Just might be easier on the tube. Any way just wondered if that was the nature of the beast, as my machine is probably better suited to cutting rather than engraving. Anything above 600 speed, causes step loss. Sorry I should have posted pics - I'll add some. TIA Nev
    Jul 2006
    83
    glass
    3 on left engraved with different power /speed to see results, 4th rastered. Sorry for the flash.
    Dec 2008
    1258
    This should be real easy, just put an inline on it the width you want for the line.
    Zax.
    Jul 2006
    83
    Is that in Design SW or Lasercut? I'm using Aspire ( primarily a 3D CNC package, but can output a dxf ) but am trying to familiarize myself with Corel ( I have X4).
    Dec 2008
    1258
    I don't have Lasercut so don't know what's possible with it, but it can be done in Corel (although I don't use that much either). In case you're wondering, I use Artcam, GSP Omega and SolidWorks.
    Zax.
  1. Raster to Vector Software
    By Ferrari2007 in forum Mach Software (ArtSoft software)
    Last Post: 10-02-2009, 05:56 PM
  2. Raster to vector
    By lez in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-07-2007, 05:54 AM
  3. Raster To Vector (R2V)
    By tknief in forum Community Club House
    Last Post: 09-28-2006, 04:46 PM
  4. OneCnc Raster to Vector
    By partsman in forum OneCNC
    Last Post: 01-24-2006, 07:38 PM
  5. raster to vector
    By teilhardo in forum Uncategorised CAM Discussion
    Last Post: 05-05-2004, 02:56 PM
