Greetings! I'm a newbie at this, literally my first post so bear with me...
I have a Sherline mill, I'm not sure what model.
I got it working in Mach 3.
I can move the 3 axis's manually and I've figured out how to reset the x, y and z to zero.
I have figured out how to load a gcode file and make the mill run it.
I am using CorelDRAW 12 to make basic shapes.
I've figured out how to use MeshCAM V3 to create a gcode file.
My question is - How do I make the same size in CorelDRAW when the shape is machined? I ask this question because I made a simple circle in CorelDRAW that was 1 inch by 1 inch.
I exported to a .png and imported into MeshCAM. I told MeshCAM that the file was 1 inch by 1 inch.
I ran the gcode produced in Mach3 and the circle was soooooo small! Nowhere close to an inch!
Does anyone have a Gcode "Ruler" program that I can run through what will correspond to real inches/mm?
Also, can anyone share with me the software they use to go from Idea to Gcode?
