Hi
I have installed my new tube using solder joints and then wrapping the join in silicon grease and silicon hv tape.
The tape is rated at 7000 v. Does anyone know if this is sufficient? I have used the laser without any problems for a week so I am assuming it is ok in combination with the grease? The power supply is a standard rabbit 40v laser power supply but I dont have any specs on it.
I am assuming the silicon grease is rated at a higher voltage is it is normally used to prevent arcing. Although there is no rating on the tube.
Anyway just curious- as the voltages are so high I want to be sure I am taking the correct steps. Ive seen videos on youtube showing bad cases of tube failure and arcing.
