512,240 active members
4,400 visitors online
Results 1 to 6 of 6
    Registered
    Mar 2007
    398
    Eagle PCB array?
    Hi all I am playing with Eagle Lite and am trying to create an Infra red LED array in a circular pattern.
    I have placed a 5mm LED but cant seem to find an Array function any where?.
    Am I blind or is this standard function missing?.
    Thanks very much
    P.S
    I did look for an Eagle software section couldn't find one (Could all so be blind and not see that as well :P)
    Registered
    Mar 2007
    398
    I take it no one knows how to do what I am asking then or its not possible without more effort.
    Registered
    Dec 2004
    1137
    You could write a ulp program (that's eagle's programming language), but to answer directly, no there is not an array type function built in. How many leds?
    Registered
    Mar 2007
    398
    Quote Originally Posted by Jay C View Post
    No trust me I couldn't I am no good at this programming at all.
    The amount of leds are unknown but I suppose I could place them all manually :O
    Registered
    Dec 2004
    1137
    Another option is to use a drawing program to produce a layout of your LEDs. Then use the ulp that converts a bmp to a Eagle layer to serve as a guide to placing the LEDs. I did this with an LEDs lamp I was redesigning, except that I scanned in the old circuit board so I could reuse the same housing and deflector.
    Registered
    Sep 2009
    104
    Quote Originally Posted by stk2008 View Post
    there is a ulp called panelize. copy your .brd file and call it something like <file>_panelized.brd. open it, run the ulp, and you can copy/paste the layout over and over in any configuration you want.
  1. Pin array
    By sp1nm0nkey in forum Mastercam
    Last Post: 07-05-2009, 03:27 AM
  2. Array with v20
    By DEW in forum BobCad-Cam
    Last Post: 11-21-2007, 12:50 AM
  3. 7 Amp X 5 Mosfet Array
    By scratch_6057 in forum Open Source Controller Boards
    Last Post: 01-28-2007, 03:24 AM
  4. LED array sequencer
    By MrWild in forum General CNC Machine Related Electronics
    Last Post: 11-21-2006, 06:31 PM
  5. Linear Array
    By hay171717 in forum G-Code Programing
    Last Post: 05-28-2004, 07:18 AM
