585,917 active members*
3,663 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam X3 Lathe arc moves reversed in post.
    Jul 2007
    131
    Hello,
    I'm using MC X3 Lathe to write code for a Mach3 controlled lathe conversion.
    The machine definision I selected is the Lathe 2-axis slant bed.
    The problem I'm having is that the post out puts a G3 arc move when a G2 is required and visa versa.
    I've tried modifying the machine definition to use lower left X turret or a upper right X turret. Still no change in the posted code.
    Thanks for any help.
    Barry
    Tormach PCNC1100, Mach 3 R3.043.037, MastercamX5 level 3.
    Nov 2007
    60
    Lathe
    Wouldn't a lower left AND upper right be the same positions relative to the spindle???
    Try lower right, and if that doesn't work, open up your machine definition manager and see if there is a place in there to configure G02 and G03 for clockwise/counterclockwise etc...
    Jul 2007
    131
    Quote Originally Posted by jolafson View Post
    I see what your saying...the orginal X turret is Upper Left. So I was hoping that Lower Left would change the relative position.
    I didn't see anything in the Machine or Control definition that looked like the arcs could be reversed.
    Apr 2003
    3578
    without having to make changes to the post program using a lower turret you will get what you need correctly.
    Cadcam
    Jul 2007
    131
    I tried a HAAS Tool Room Lathe definition which used a lower turret. This created NC code were the X moves away from C/L in the negetive direction. This caused other issues. I finally found a setting in the controller that was active to 'reverse arcs' ???
    Had nothing to do with Mastercam.
    I appreciate the help anyways, thanks
  1. Fagor 8055t lathe / Mastercam post
    By MBFisher in forum Fagor Automation
    Last Post: 01-13-2021, 03:13 PM
  2. MasterCam X3 post for Doosan lathe
    By Quickers in forum Mastercam
    Last Post: 02-13-2009, 09:28 AM
  3. Need post for mastercam 9.1 for cnc haas lathe
    By katsbobo in forum Post Processors for MC
    Last Post: 08-23-2008, 11:47 PM
  4. looking for a mastercam post for a leadwell lathe T-8sm
    By ronfournier in forum Post Processors for MC
    Last Post: 02-19-2008, 03:14 AM
