585,991 active members*
4,664 visitors online*
    Jan 2010
    13
    mach3 plasma help
    Its easy to set up axis calibration on the mach router program but how do i do it in the plasma, my table is way off and in the plasma setting their is no calibration...
    Jan 2010
    13
    anyone?
    Aug 2007
    215
    what screenset are you using?
    Jul 2005
    2415
    You don't need axis calibration to setup MACH. All you need is a tape measure, and a calculator.
    Chuck a small drill bit or pointer tip
    Zero the X axis and use Z to mark the table where it is.
    Use the MDI window and send the axis out 10 inches using G00 X10 [enter]
    Now for the math part:
    Measure from the start point to where it is stopped (center to center)
    write down the number 10.000 (your distance you told it to go)
    write down what the actual distance is (use decimal notation)
    Now subtract the smaller number from the larger one to get the difference.
    Lets say you read 10.125 on the actual tape. you find there is a difference of .125 (error)
    Now open the motor tuning for that axis and write down the Steps per unit number.
    With our calculator divide the error (.125) in this case by the original 10.00 you called for. .125/10.000 = or .0125. What that represents is a ratio of the error.
    Take the steps per unit you wrote down and multiply by the error ratio. Now you have the number of steps to add (if you are short) or subtract to get closer.
    BEFORE you change the Steps per unit send the axis back to zero using G00 X0 THEN put in the new steps per unit.
    Run the test again and you should be much closer. Here is the magic part: The longer you make the distance to easier the error is to see and correct. After a few tries you will be dead on at 36 or 48" .
    Do it a couple of times and it's really fast to calibrate the axis. The calibration macro in MACH does essential what I outlined but does the math for you and lets you type in the numbers.
    If it's a plasma table lay a piece of MDF out on the grid and clamp it down so you have something you can mark (and even use as a scratch pad!).
    It's basically taking a reading, finding the amount of the error, converting that to a percentage of the total and using that percentage to adjust the steps per unit. It's pretty easy to see that is you are off by 5% over a distance, adjusting the step count by 5% would correct it. It's also obvious that the longer the test run the greater the accuracy of the process.
    TOM caudle
    www.CandCNC.com
    Nov 2011
    hi there has anyone found out a way to speed up the x and y movements of a table as it travels from cut to cut
  1. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
  2. mach3 plasma restart mid-job?
    By johnt in forum Mach Plasma / Laser
    Last Post: 12-04-2007, 05:59 AM
  3. Mach3 Plasma G41 G42
    By CARLES in forum Mach Plasma / Laser
    Last Post: 07-25-2007, 11:08 PM
  4. ArtCAM & Mach3 for Plasma and Oxy
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 05-31-2006, 07:01 PM
  5. Mach3 Plasma
    By anthony in forum Mach Plasma / Laser
    Last Post: 05-19-2005, 12:21 AM
