586,000 active members*
4,834 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 4 of 41 2345614
Results 61 to 80 of 808
  1. #61
    May 2003
    132
    Re: Huanyang Chinese VFD settings and manual here!
    60 X Hz = rpm
    60 X 300 = 18000 RPM
    60 X 400 + 24000 RPM
    you should be putting out 18000 RPM. Hope this helps
    Donald Clifton
  2. #62
    Apr 2011
    31
    Quote Originally Posted by Don C View Post
    60 X Hz = rpm
    Donald Clifton
    Hello Donald. Yes, I'm fairly certain it's putting out 300hz as the VFD shows, however the issue is rott on the VFD doesn't read 18000. It was my understanding that it could/should read 18000. Am I mistaken?
  3. #63
    Apr 2011
    31
    btsioles
    Have not done an 18,000RPM with this spindle, so if you were getting to 300Hz then you were at max speed, It would be wise to use the settings you had put in, obvious the seller is just that & does not know how to set the drive up
    You have an air cooled spindle so it is very important, that you have the minimum speed set correct, 120 Hz will be to low, looking at the photos, they are saying that your spindle is 400 Hz with a minimum of 300Hz
    Thanks for the reply. I'm confused. The spindle says 300Hz. Where do you see it's 400 Hz? I should set PD011 TO 300? Why are others using 120?
  4. #64
    Apr 2015
    17
    I have the same products with some small variation as you can see in the picture.
    The problem is PD070, switch 0 to 1
    With this configuration after factory reset works perfectly, tested with a laser tachometer.
    PD001 - 0
    PD002 - 1 (Board Potentiometer, you leave it at 0)
    PD003 - 300
    PD004 - 300
    PD005 - 300
    PD009 - 15
    PD010 - 8
    PD070 - 1
    PD072 - 300
    PD141 - 220
    PD142 - 8.6
    PD143 - 2
    PD144 - 3000
    If you have other voltage in your house, just change the parameters 220 to x.
  5. #65
    May 2003
    132
    I'm not sure but one of the buttons should scroll thur hz, rpm, amps.
    Don
  6. #66
    Apr 2011
    31
    Great thanks Dytoven. What about PD011? Isn't it important to set that to something other than default? Have you been running the spindle long without issues?
  7. #67
    Apr 2015
    17
    I have PD011-0 as factory default and I remember that the change gave me problems, was running more than 10 minutes on the floor to test with tachometer, do not warm or making strange noises, but I have not tried still in real work. I hope it works well too.
  8. #68
    Apr 2011
    31
    Quote Originally Posted by Dytoven View Post
    Will you elaborate on what types of problems? Sorry for all the questions, I'm just trying to be thorough.
  9. #69
    Apr 2015
    17
    I have no experience with these products and my knowledge of electricity and electronics is basic, but when you enter some incorrect parameter sure resulting in low speed, vibration or bad sound.
    I read faster than you can adjust the torque, but I have not tried. If you make it, write something here.
    Sometimes one can only rely on luck.
    Now I just see in my motor plate that says "fail". certainly they sold me something rectified. (nuts)
  10. #70
    15362
    PD011 It will not cause you problems, you will get problems if you don't set it, this is the minimum speed that the spindle is allowed to run, it should always be set to the slowest speed to suit your spindle, for your air cooled spindles around 200 Hz, is probably the best you can hope for without over heating
    Mactec54
  11. #71
    15362
    Quote Originally Posted by btsioles View Post
    In the second photo, I see why, that is for countries that use 50 Hz
    The others are water cooled spindles & can run slower, yours being air cooled they can not run that slow as they rely on the motor fan to keep them cool
    200 should be fine for PD011, just check the temperature if it gets hotter than what it is at 18,000 then increase to 220 & try it Etc
    Acceleration & Deceleration should be similar numbers also, Deceleration is just as important as Acceleration if it takes 15s to get up to speed then Deceleration should be similar, no less than 12s
    Mactec54
  12. #72
    15362
    There is no luck about it, the Parameters have to be correct, or Fail it will be
    The VFD Drive will fail in a flash, with using wrong settings, this is not something you can just set any Parameter & press the start button, ( 1 ) wrong setting can/will smoke your drive
    Mactec54
  13. #73
    Apr 2011
    31
    Great, thanks for the info mactec54. I'll try this tonight and report back.
  14. #74
    15362
    btsioles
    I did not see in your list PD 014 & PD 015
    PD 014=12 Acceration
    PD 012=12 Deceleration
    These need to be set, you can start at 15s, you can adjust to a lower setting when you get used to how your spindle runs
    Mactec54
  15. #75
    Apr 2011
    31
    btsioles
    Great. Thanks so much for the info. I will set both PD014 and PD015 to 15. Hopefully with these changes, and PD070 to 1, I will be set. I will report back tonight.
  16. #76
    15362
    btsioles
    If you do PD070 then set these Parameters also
    PD072=300
    PD73=200
    Mactec54
  17. #77
    Apr 2011
    31
    btsioles
    PD072=300
    PD73=200
    Okay. How about pd144? Is that max rpm 18000 / 8 amps, giving 2250? Or do I use 3000? Is PD070 = 1 the solution to my ROTT problem?
  18. #78
    Apr 2011
    31
    Okay, the suggestions seem to have worked. Here is a recap.
    3kw 300hz 18000rpm air cooled square spindle. Inverter input 240v USA.
    The following settings in this order:
    Reset to factory defaults
    Pd001=0
    005=300
    004=300
    003=300
    072=300
    073=200
    006=2.5
    008=220
    009=15
    010=8
    011=200
    014=15
    015=15
    070=1
    142=8.6 (motors amp rating)
    143=2
    144=3000
    I only ran it up to speed then stopped it. Rott showed 18000, Hz showed 300. I'll run it for an extended period this weekend to verify it's not getting too hot.
    Thanks everyone for the help!
  19. #79
    15362
    Use the 3000 for the PD144
    As for the PD070, it has more than ( 1 ) use, there would be no harm in trying it at default of ( 0 ), to see if you have any change in the RPM, it is normally used for a remote analog pot/control, now that PD072/PD073 is set, all ( 3 ) Parameters are related
    Mactec54
  20. #80
    Apr 2011
    31
    Thanks for the info. So I just ran spindle at 200 Hz for about 5 minutes. Then up to 250 for a few more minutes. Then 300 for a few more. In that 10 minutes or so the round black spindle body above the collet side got warmer than I expected. The square body was not as warm, but was warm to the touch. I hadn't expected it to get warm that fast. I wonder how warm it would get while cutting.
    Is this normal?
  1. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  2. Replies: 4
    Last Post: 02-16-2017, 05:42 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
