585,668 active members*
4,148 visitors online*
IndustryArena Forum > CAM Software > Surfcam > 5 axis post processor
Results 1 to 6 of 6
    Sep 2009
    Im running a parallel to curve command on a blade dovetail that requires 5 axis processing on a Haas VF3 trunniun. When I run simulation or verification on the computer the tool path is fine. When I run the code on the machine the primary rotary table is rotating a full circle near the center of the tool path. Is there a limit I can set to prevent these little circles?
    Nov 2010
    Can you post the code?
    Sep 2009
    Yes I can post it out. The posted code is where I see the problem
    Nov 2010
    I was trying to say that weather you can send the code so that we can take a look at it
    Sep 2009
    I'LL try to upload the file
    Feb 2011
    252
  1. Post processor 5 axis
    By frrmrk in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-21-2013, 11:30 PM
  2. post processor 5 axis
    By sml2010 in forum PowerMILL
    Last Post: 02-28-2013, 06:56 PM
  3. 4-axis post processor
    By denjo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-18-2008, 07:01 PM
