Originally Posted by
southern cnc
Thanks for the reply Rusty.
My control is the Mazatrol M-2. Could you tell me the pinouts of the cable
you are using? I've tried the cable that the CMT (the blue box with floppy drive) uses, with no luck.
It sends to the computer, but when I try to upload the saved file to the machine, it only sends a few bytes, then stops. I am not sure that what is sent to the computer is correct.
Could you also send your parameter settings? I can make the changes between the M-plus and M-2 controls. I would also like to get it working with
a lathe that has the T-2 control.
I surely do appreciate the help. If I can get this working, it will save
a lot of time.
