585,956 active members*
4,257 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Spindle Assembly Drawing for Mori VMC SV500/40
    May 2010
    Post Spindle Assembly Drawing for Mori VMC SV500/40
    Hi all,
    Looking for the spindle assembly drawing for Mori SV500/40.
    Actually the spindle is not holding the tool and seems like the collet is not opening.
    Need the spindle assembly drawing to disassemble it recity.
    Can any body help.
    Regards,
    Shivek Sood
    Feb 2009
    6028
    If the collet is not opening, most likely need to bleed the Tool unclamp Cylinder. It's a air over oil system that is closed loop during automatic tool change. If the tool is pulling out, then you need to change the springs/collet. The unclamp cylinder has a small black block sticking out, that has a small tube pressed in and a socket head screw with a lock nut. Put the machine in MDI mode, then open the valve till all the air comes out. Tighten the cap screw (closing the valve) then go to manual and try. You may have to do it several times.
  1. Arrow 500 need drawing for drawbar assembly
    By scudzuki in forum Cincinnati CNC
    Last Post: 08-22-2016, 08:51 PM
  2. Mori SV500-Need to find skip X bit
    By ASIGuy in forum Mori Seiki Mills
    Last Post: 03-09-2009, 02:13 PM
  3. Boss R2E3 - need drawing of head assembly
    By Scott Kelley in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2008, 09:31 PM
  4. information needed on spindle assembly
    By intelsingh in forum MetalWork Discussion
    Last Post: 02-23-2005, 03:49 PM
  5. SV500 servo drives
    By eman5oh in forum Servo Motors / Drives
    Last Post: 02-14-2005, 10:15 PM
